SOLVED: 1988 2.9 5-speed “popping and gurgling” consistently when coasting in gear or down shifting
GingerKing13
9
Defuniak Springs, Fl
1988 Super Cab
2 inches
31x10.5xR15
Hey guys,
1988 2.9L 5-speed 4x4 super cab
intermittently on idle and when driving the truck has a little stumble (flutter in RPM down). Generally it idles and runs smooth but have noticed more lately stumbling a little bit on the highway and stumbling tach and RPM on startup occasionally.
consistently exhaust burps and pops when downshifting or coasting in gear, even just reving it up it gurgles on the way down.
truck has new plugs, coil, distributor, ICM, TPS, IAC valve.
Has anyone ever experienced this??
rusty ol ranger
2.9 Mafia-Don
7,758
Michigan
177 CID
Hows the plug on the coil connection look?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You replaced the IAC... does it function properly?
When you start it up cold... is the idle raised initially the settle down to a normal idle speed?
rusty ol ranger
2.9 Mafia-Don
7,758
Michigan
177 CID
GingerKing13
9
1988 Super Cab
2 inches
31x10.5xR15
Yes works as it should and replace by OEM motorcraft.
GingerKing13
9
1988 Super Cab
2 inches
31x10.5xR15
Nah i mean the main plug going into the coil. The black plug with the red and green wires
Its seen better days but the connection is tight on the two terminals.
rusty ol ranger
2.9 Mafia-Don
7,758
Michigan
177 CID
Id replace it. I believe that controls your tach. If its bouncing the trouble could be right there
GingerKing13
9
1988 Super Cab
2 inches
31x10.5xR15
Okay, there about $10 I could do that. What about the capacitor that runs off of one of the green wires and is mounted on the fender liner?
rusty ol ranger
2.9 Mafia-Don
7,758
Michigan
177 CID
I believe all that does is control ignition related radio noise. Mines been gone for years
alwaysFlOoReD
5,172
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Would a leaking injector cause this? Easy test is hold the gas pedal to the floor and try to start the truck. It's the "clear flooded engine" procedure. The engine should turn over but not try to start.
rusty ol ranger
2.9 Mafia-Don
7,758
Michigan
177 CID
Its possible but an injector shouldnt make the tach bounce...unless hes also getting a notable RPM difference when it happens
GingerKing13
9
1988 Super Cab
2 inches
31x10.5xR15
The tach doesn’t “bounce” by itself. It does follow the engine rpm as it stumbles or hesitates, or surges, etc.. I can feel the fluctuation as it appears on the tach.
rubydist
870
Denver
Ford Ranger FX4
I would take a good look for an exhaust leak before the cats. There may be more than one issue here because that should not cause the bouncing tach, but can certainly cause the burble or however you want to describe the noise on decel.
GingerKing13
9
1988 Super Cab
2 inches
31x10.5xR15
SOLVED: Replaced the ICM and it idles perfectly, no lag in throttle input, and no more popping on the decel. Thanks for the input guys.
FYI: My ICM screws were PHILLIPS head! not 7/32 or a torx.
