Spare Parts For Off Roading?
XionicWaste
April 2012 OTOTM Winner
19
Menomonie, WI
Solid Axle Swap 4x4
3"
37x12.50 Pitbull Rocker MTs
Custom everything! Purists look out!
I'm going to Moab, UT for spring break and I was wondering what I should bring for spare parts? I already want to get a spare drive shaft but what else should I bring or keep in the truck?
mini274
Elizabethton, TN
302
If it was me i would take of course spare tire jack the basic tools a front and rear drive shaft... then extra oil antifreeze a hose or 2 clamps.... i always carry an extra coil on out of state trips trans fluid.. and a tow strap pr chain which is a must.... diff fluid and some other stuff that i probably forgot which most you prob knew
BlackBII
Ranger Custom
Truck of Month
984
UT
Hubs, Axleshafts, U-joints
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
I have most of that stuff already, I think I will just go with a rear shaft for now, it will be enough to get me off of the trail and back home, unless you can talk me into getting a front too... I have auto locking hubs so if I break those then I will get some decent manual locking ones, as for spare hubs Im going to take my chances and not buy those... I need a wider assortment of fluids but I think I should be good to go... What price would you pay for a spare rear drive shaft from a salvage yard?
Mudhound
Eaastern Ky- out in the woods ( literally)
87
173 and 331 CI
You might also want to consider a set of ratchet straps, and NOT the crappy ones with the pull type buckle. get the real deal. You would be AMAZED at what you can use them for... holding up a tranny crossmember that manged to loose the bolts off of one side, strappng a trcak bar up to the engine mount, numerous uses.
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Like a 3 inch or a 1 inch strap?
IlovemybroncII
greenville sc
1998
198
Chev
For
350/2.9/2.9
take a whole spare truck lol just jk but I would take a extra drive belt or belts those things break at the damest times and some jb weld so if you knock a hole in tranny oil pan ect you can at least patch it up so it will hold fluids
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
thats a good point, ill add that to the list of possible spares.
spdcrazy
Homer, alaska
mostly 86
B2
2.9 bored and cammed
toilet paper is a must!
nothing like pooping in the desert!
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
LMAO you are absolutely correct on that one!
Junk Collector
Truck of Month
4,872
Rapid City SD
As long as you have a good spotter you shouldn't need a driveshaft... that said... I have trashed a couple. I have a spare at my house.
x2 on what BlackBII said. Spare hubs especially. I've grenaded both hubs in a 20 minute span before and it would suck to have to walk for help or get towed just cuz you don't have spare parts.
