Speed Sensor Issue
carguy200550
Ok I bought a 1994 ranger 2.3L 5 speed truck and the speedometer wasn't working. I crawled under the truck and found the speed sensor zip tied out of the way to the frame (not in the tranny). However when I looked to the spot where the sensor should go I found it to be blocked off (see pictures). The only thing I can figure is that someone put in a new tranny and didn't get the right year model to accept a mechanical vss. What can I do to get my speedometer working?
carguy200550
on further inspection it looks like there is a metal plug that could possibly be removed, anyone have any input on this?
Try removing it.
Earl43P
38
Farmington, Pa
Ford F250 4WD
That IS a newer transmission.
The first photo shows the boss where the VSS would have gone, forward/Driver side of the tailshaft housing.
The plug in the second photo, beside the label, is NOT for the VSS. That is the FILL plug. Nothing in the second photo is VSS related.
I'm pretty sure you won't find any gear drive guts inside that trans to drive your VSS. Since it is a manual, I recommend just putting a $100 GPS in and call it a day.
An off the wall option is to tap into the rear axle (ABS) VSS wires (LG/BK and R/PK) and connect those to the existing VSS wiring (GY/BK and PK/O you already found at the transmission). The R/PK and LG/BK wires are also available at the RABS Module and the RABS Test Connector. I can't assure you the pulse rate is the same, but I suspect it will be. Worth a shot.
Report back if you do that wiring and it works. Will help a lot of members!
cbeck
The 99 trans I bought for my 94 looks a little different from your picture. my99 loons likeit was properly cast but not final machined, no surface plug but hole is blind with no retaining screw hole either. Let us know it works out. By the way, my 94 driveshart and 99 slipyolk use different joints,solved with napa joint # 353.
