eb89
- Jan 22, 2009
- 0
- Ford
- Engine Size
- 2.9
So my 90 2.9 ranger is having some starting troubles and I'm beginning to wonder if its the flywheel, but i want to make sure I have crossed everything easier and cheaper off before i go there. My starter went bad along with my module about a month ago so i put a rebuilt starter and new module in. everything worked well for a few days to a week, but as it got colder it started starting slower and not always on the first try. Then my solenoid got stuck closed leaving my starter running even after taking the keys out. so I disconnected the battery as quick as i could and replaced the fender mounted solenoid. but the starter troubles are still there(starter will whine and/or grind the first and sometimes second key turns before finally engaging properly). i was wondering if maybe the starter got damaged when the solenoid got stuck so I'm going to test that next, but if not that then what? I was beginning to wondering if maybe my flywheel is damaged and will therefore continue to eat up starters, and if so is there any easy way to check this?
