Starter Solenoid Issues
Jay_Chain
Colorado Springs
1979
5.0 coming soon
I replaced the solenoid, now my engine won't crank. Think I may have wired it up wrong. I can't make any sense of the wiring diagrams, does anyone have a picture of what it should look like? Its an '86 2.3l manual
3,614
The big wire that goes to the starter goes all by itself on one side of the solenoid.
All the other big wires go on the other side.
The little red and blue wire goes on the little post.
Jay_Chain
Colorado Springs
1979
5.0 coming soon
There's two little posts. is one of them empty?
3,614
Probably. If it doesn't work on the one try the other.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
Start with the small post further forward, that's the one used on most of my solenoids for the small wire.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Yes, it's the one on the left side of the starter towards the front of the vehicle. Not sure what the other one does but some solenoids that I've seen have only one so it makes it easier...
You might want to cut the boot off that wire and use a crimp on round eyelet instead of the boot...the boots can become a source of aggravation over time...
Jay_Chain
Colorado Springs
1979
5.0 coming soon
It was wired correctly. The cable running from the battery to the starter was torn up.
