creepinjeepster
- Oct 16, 2009
- 2
- Radcliff, Kentucky
- 1990 and 1991
- Ford
- Engine Size
- 90-2.9 and 91-3.0
Now that I've got the vacuum line issue solved, I'm still having starting issues. I've looked through the arcives and haven't seen anything that speaks of issues like mine so.........
When the engine is cold and it's started up, it starts without any hesitation. Maybe one and a half to two rotations before she cranks. When the engine is warm however, sometimes I have to hold the foot down on the excelerator which would make me think fuel problem, but I don't have to every time. The engine will turn, but stop then turn, then stop until she finally cranks, kind of like with a half dead battery. It makes me think the timing may be off some. I've tried adjusting it several times by ear. I can't use the timing marks as I can't find a mark anywhere on the balancer pulley and the actual timing marks that are SUPPOSE to be bolted to the front of the block aren't there. Previous owner removed when working on engine once and never replaced it. (That was ingenious) Never had to remove them myself on any vehicle I've ever worked on.
So is it possible that the distributor could be 180 out? Been a while since I've messed with one I can't remember, but I think it wouldn't start at all if it was, if I'm remembering right.
I've even tried pulling the dist. after putting eng. to TDC and realigning dist. but this hasn't helped either. So anyone got ideas on this?
