tekkatekka
- Jul 17, 2013
- 5
- ford ranger
I have a 91 ranger 4.0 4x4. It has a starting problem. It used to start very quick as the starter turned over the engine. Now after sitting all night I have to turn over the starter quite a long time before the engine starts. What seems to work is if I turn it over for 3 seconds or so, stop, then turn it over again then it starts quickly on the second try. This happens overnight or whenever it has been sitting for a while. If I try to start it right after I turn it of it starts right up like it used to. When it has been a cold night in single digits it will start quickly in the morning just like it used to on the first try. Once started it acts like it always has with a higher rpm till it warms up. I am thinking it has something to do with how it gets fuel during the cold start and wondering how the system works during that time. Also wondering if the oxygen sensor is involved with cold start.
Just before the starting problem happened some things were done to the truck.
New clutch and an engine light that lead me to change the oxygen sensor and that fixed the engine light problem. Wondering if the oxygen sensor could be bad and if that could cause the starting problem? Any help would be greatly appreciated as I need to go on a road trip soon.
