2.3L ('83-'97) Starting up an engine
97ranger22bronco
22
Dallas, TX
Kind of a silly question, I'm planning to perhaps crank up the engine in the '97 this weekend. With it sitting for so long, I figured it may need a little help. If it had a carb, I'd spray ether into it; is there a similar process for an EFI engine?
alwaysFlOoReD
5,163
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Depends how long its been sitting. Under a year crank it up. Longer maybe drain and put in fresh fuel.
I let my summer car sit for 4-5 months, just make sure the tank is full.
Make sure battery is charged.
97ranger22bronco
22
Dallas, TX
It sat for 14 years :D I'm draining the fuel and changing out the fuel pump this weekend. Already changed the oil and flushed the coolant.
4.0blue98
I don't feel tardy...
705
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Wow 14 years! Could pull the fuel pump relay and crank it a bit to get some oil pressure and flow. I'm assuming it will crank and isn't stuck?
scotts90ranger
4,522
Dayton Oregon
2.3 Turbo
Yeah, that, maybe unplug the inertia switch at the front top of the passenger side carpet to crank and get oil pressure first but I don't think I'd be too worried...
pjtoledo
3,011
Toledo Ohio
Fords
3.0 2.3
14 years??
I would pull the plugs, squirt some oil in the cylinders and crank it for 30 seconds or a minute.
get the engine oil pumped thru it.
then install plugs and start. it will smoke.
Blmpkn
Toilet enthusiast
6,428
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Holding the gas pedal to the carpet when you go to crank it will shut off the injectors and allow the oil to circulate/build pressure before firing.
scotts90ranger
4,522
Dayton Oregon
2.3 Turbo
So says the legend, my '97 doesn't do that but maybe the TPS isn't working right since it doesn't go all the way to 100%, stops at like 93%
rusty ol ranger
2.9 Mafia-Don
7,746
Michigan
177 CID
My ranger sat for 12 when i got it.
Dumped fresh fuel in and cranked it up
