static drop?
phatcap
the mitten
2.5L
what does this term mean?
th31d10t
Sumter, SC
2.3 4cyl.
A static drop is one that you can not easily change your ride height. These are your 3/4, 5/7, and so on drops. The truck has been lowered so far and stays at that height unless you do suspension work.
When you put hydros or bags on a truck it is not considered a static truck because the truck can be lowered and lifted at the flip of some switches without have to spend time doing suspension work.
phatcap
the mitten
2.5L
ok, that makes sense. thanks for clearing that up. i would love to bag mine but too much $$$ for me right now. i'll go with the "static" drop then. thanks again.
Insanejughead
33
Missouri
'94, '86
2.3T
Static... well, you know what that is.
Drop... you should know what that is too.
So, if you put two and two together, you should get four... Right?
"Static Drop" = The act of lowering your truck by sending 1.21 gigawatts of juice through your flux capacitor.
Hahahaha... tH3Id10T nailed it on the head for you.
motohead771
Colorado
4.0L V6
Im guessing its not 3/4 of an inch so what do 3/4 5/7 signify?
Insanejughead
33
Missouri
'94, '86
2.3T
Those specify how much (in inches) that the Front/Rear of the truck was lowered.
I have a 4/4 drop. 4" front drop, and 4" rear drop.
Left to Right, front to back...
motohead771
Colorado
4.0L V6
thats cool. Its what I figured, becasue 3/4" is nearly nothing, but 4" and 4" thats quite a bit.
Insanejughead
33
Missouri
'94, '86
2.3T
Not really...
I did start rubbing the inner fender when I cut my springs down a hair. I was just going to stick with the 3/4, but the truck sat level and I honestly am not a fan of level trucks. I like them to be raked with wider tires in the back. That's where my 1.5" spacers come in handy. Makes it "look" like I have bigger tires while I really don't.
For driving's sake, I'm keeping the drop right there. I don't have any desire to go bagged or sit level.
Army
2.3
A 3/4 is more than enough, if you have no intention of notching your frame. The drop, and lo-pro skins will get you really close to the pavement, yet keep the original feel of the suspension and drive.
I still run full size 15" rubber, and have ground off at least an inch of the factory mud-guards. I do not rub the tire at all.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
Depending on how you drop the rear, you won't have to notch it for even 6" of drop. I didn't do a flip kit, I bought drop leaves for mine. I cut my bump stops in half and that is the only mod I have to do. If you go 5" up front, same deal, cut your bump stops. I can't run OEM tire size. I had 225/70/14 stock and they rub up front. I currently am running a 225/60/15 front and 275/60/15 rear. No rubbing except for dips I take too fast.
James
