staying closed loop
librum
NOVA
Probably having a 'duh' moment... The 89 2.9, having an occasional backfire issue. For t/s purposes only, is there a way to lock into closed loop (paying no attention to the O2 sensor)?
You are asking about keeping it in Open loop.
Just unplug an O2 sensor.
Pauls 4x4
ASE Certified Tech
Colton, CA
Unplug any major sensor and it cuts the feed from ALL. So you kill the ECT the ATS the o2, etc the ECT ignores all of them (adaptive fuel off). Most early obd1 systems don't feed filler values like obd2 and one bad value can kill the whole data stream because it can't "fall back. Codes also don't always light the cell so many times you have to manually check them to find them, and some never set to memory. Its like a TI82 not a PC.
The gist being "unplug to test" is really bunk on obd1. If you are backfiring it also can be ignition, fuel, and both aren't monitored. But to rule out 02 you need an equivelant of the brick tester or a multimeter. Then the other sensors need to be checked too. 02 sensors only really go bad in specific cases (coolant in exhaust, gas flood, or super lean) so another preexisting issue won't be fixed even if it is bad.
Just my 2 cents
librum
NOVA
Thanks for the response Pauls 4x4. I confirms what I have already learned.
