Steering knuckles
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Would the steering knuckles on a 97 Dana 35, be the same as on an 87 Dana 28? I have a crack through one of the lug holes in my drivers side, it's the 35. I can't find a replacement anywhere! Might try to go look at some off of a 28, but don't know if they'd be the same or not. Anything, anybody could tell me would be greatly appreciated.
97RangerXLT
TRS 25th Anniversary
3,964
Fishers, IN
2"
31"
Nope, and I believe that the 97 has a different knuckle than even the earlier d35's because the brakes are dual piston callipers and attach tot he knuckle differently. I also think that the 98 is different because Ford switched to IFS style front suspension in 98. so you might be looking around for a bit or getting it from Ford (if it is still available)
you might have to widen your search radius a bit... :(
AJ
The 87 knuckle and the 97 knuckle are close. Like Pluto and the Sun are close.
The knuckles from a 28 will not fit a 35, and the 95-97 knuckles are setup for the bolt-on calipers, but the 94 and earlier all used slide pins.
The fact that your axle falls in that short year range is why you are having so much trouble finding a knuckle.
I have to question if you actually need a knuckle though. You said you have a crack in the lug hole. Well the studs for the lug nuts aren't attached to the knuckle, they come with the rotor. Got any pics of the problem?
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Well, I went and looked at them. I believe they would not mount up, and they are definitely different. No where near as beefy as the 35s.
CrazyLikeAFox
Westminster, OHIO
Undercompensating
I guess I should have specified. Not the lug hole, but the lug style bolts that mount the spindle to the knuckle. Sorry for the confusion.
Get it welded up.
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Maybe a dumb question, but what are they made of?
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Also, I have pix, but won't let me upload from phone.
The knuckles are cast iron.
CrazyLikeAFox
Westminster, OHIO
Undercompensating
That's what I thought. Thanks guys! Really appreciate it!
black_demon69
142
AZ
4.0l
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
if i remember right cast iron can't be welded. but i am by no means a expert on welding
In day of old you could not get a good weld on iron. Today, you can get just about any metal that doesn't burn with heat welded.
Spott
21
SE Idaho
Cast iron can be TIG welded with nickel-99 filler, and I think EverDur (silicon bronze) will work as well.
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Does anybody know how many different 4x4 knuckles there for 97? 4.0 with 5 speed manual if that matters. Sorry to keep posting here in the urgent section. My trucks on stands in my neighbors side of the carport.
CrazyLikeAFox
Westminster, OHIO
Undercompensating
Also mine has dual piston calipers. Thanks!
