2.3L ('83-'97) Still dealing with a loud popping while attempting to crank over
Status
Not open for further replies.
RustRatz
22
Arkansas
Ford ranger
I honestly have no idea with this truck. Replaced a ton of parts it could’ve been, but none of them solved it.
Any ideas?
1992 Ford Ranger 2.3 5 speed
Replaced ignition control module, crank sensor, plugs, etc
franklin2
1,769
Virginia
Where is the popping coming from? The intake? The exhaust? If either one of those, do a compression test on all the cylinders. If one is low, it might have a valve stuck open.
Junk Collector
Truck of Month
4,851
Rapid City SD
You are going to get better help if you just stick to one thread instead of posting new ones.
Status
