Shifting between 2H (2WD High) and 4H (4WD High)
• Move the 4WD control between 2H and 4H at a stop or any forward
speed.
Note: Do not perform this operation if the rear wheels are slipping.
Shifting to/from 4L (4WD Low)
Note: Some noise may be heard as the 4WD system shifts or engages.
This is normal and should be no reason for concern.
1. Bring the vehicle to a speed of 3 mph (5 km/h) or slower.
2. On vehicles equipped with an automatic transmission, place the
transmission in N (Neutral). On vehicles equipped with a manual
transmission, press the clutch.
3. Move the 4WD control to the desired position.
• If the vehicle speed or transmission gear requirements are not met,
the shift will not occur.
• If shifting into 4L (4WD Low), wait for the 4WD LOW light in the
instrument cluster to turn on indicating the shift is complete.
• If shifting out of 4L (4WD Low), wait for the 4WD LOW light in the
instrument cluster to turn off indicating the shift is complete.
