Stupid question but...
kevinbmx77
If i have too much rear travel and no limiting straps, can the drive shaft fall out of the transmission?
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Yes, 1 of 2 things will happen.
1. The driveshaft will pull out of the back of the transmission
2. The driveshaft will separate and pull apart from itself if it's connects with flanges on either end (4x4's).
Neither is good. Run at least a center strap if you're getting close, and obviously don't stop it when it's only got an 1/8" to go before it falls out.
kevinbmx77
Thanks for the reply, how can i make sure i put the right size limiting straps and do you think a chevy 64 leaf swap with flipped hangers and shackled will be too much in a 94 single cable 2wd
alwaysFlOoReD
5,192
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Jackstands, cycle the suspension.
Dune Runner
Alpine, Ca
Limit straps are always a good idea on anything going offroad.
