swapping 2.9 l wiyh 4cyl.
Hardcowboy1
Weldon CA 93283
Ford ranger
Nope. It bolts to a 2.9.
ok what im trying to do is take my 2.9 and tranny out and put the dual over head cam motor with 5 speed transmission in .what i need to know is if my trasfer case off of the automatic on the 2.9 will bolt up to the five speed on the 4cyl and if not is there away to make it work. i know i have to change all the wiring and have the harness and the brain for it. this is all new to me thanks for your time.
Hardcowboy1
Weldon CA 93283
Ford ranger
Which motor do you want to end up with?
i want the 4cyl the 2.9 had a lose of power and finally stop running . i trade for this 4cyl and 5 speed hoping i could just drop it in and go but doesnt sound like it
17,953
SW Iowa
No, and 4cyl 4wd transmissions don't really grow on trees either.
Hardcowboy1
Weldon CA 93283
Ford ranger
so the dual over head cam motor has no power then. man this is killing me
snoranger
Professional money waster
ASE Certified Tech
13,717
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You said the 2.3l is from a 94... that would be the SOHC 2.3L, not the dual. The DOHC 2.3l wasn’t available until late 01.
Hardcowboy1
Weldon CA 93283
Ford ranger
ok next question why would the 2.9 suck tranny fluid up into the motor and could that cause the motor to stutter
snoranger
ASE Certified Tech
13,717
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Hardcowboy1
Weldon CA 93283
Ford ranger
i pulled the motor out of a wrecked truck that someone had cut the back half off for a trailer there was no paper work except a reg' in the glove box that said 94 on it not sure if it even goes to the truck just assuming and i know what that means lol
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
On the automatic transmission there is a valve on the outside of the case near the back on passenger side. There is a vacuum line that runs from the valve up to the intake manifold. If the diaphragm breaks then trans fluid gets up into the motor.
(Having a brain fart moment and can't remember the name of the valve)
Hardcowboy1
Weldon CA 93283
Ford ranger
ok went and pulled tag off the door it says 04/92 does that make a differance no were could i find the motor size
Hardcowboy1
Weldon CA 93283
Ford ranger
regardless i cant bolt the transfer case to the five speed ill have to find another tranny even if i keep the 2.9 i dont want the automatic id prefer the five speed how hard would it be to find one four the 2.9 insteAD .IM WIEGHING MY OPTIONS I DONT HAVE ALOT OF CASH TO WORK WITH I MIGHT EVEN JUST DROP THE 4 BANGGER IN JUST NOT HOOK UP THE FOUR WHEEL TILL I FIND A TRANNY IF THAT WILL EVEN WORK ANY ADVICE WOULD HELP HERE THANKS
Hardcowboy1
Weldon CA 93283
Ford ranger
THANKS FOR YOUR TIME IHAVE TO GO COVER MOTORS RAIN COMING ILL CHECK LATER SEE WHAT WAS SAID THANKS AGAIN
snoranger
ASE Certified Tech
13,717
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
If your short on cash, just replace the vacuum modulator (@alwaysFlOoReD). That’s the cheapest way out. You can have the truck up and running for next to nothing.
