Switching from a standard to a automatic
bf750
12
Ky
2. Crap
It is what it is
bf750
12
Ky
2. Crap
It is what it is
I need to know where the tc plug gets it power and ground from
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Ground from pcm ...
Power off of sensor common from eec power relay
bf750
12
Ky
2. Crap
It is what it is
Thanks for info. Would you know what pin numbers they are
bf750
12
Ky
2. Crap
It is what it is
Is there one for a 1988 my tcc is a 2 pin not a 3
8,374
Good info on this image: https://www.explorerforum.com/forums/media/a4ld-specification-chart-from-transgo.39537/full
TCC solenoid wire runs to pin 53 on computer, but MANUAL TRANS computer won't have the firmware/software inside so pin 53 won't do anything
You need an automatic trans computer
People have used Speed sensors to manually ground TCC solenoid
Yes, 12v for solenoid comes from EEC Relay Power On wire, they are red and run to fuel injectors, IAC Valve, EGR solenoid(if so equipped) and computer pins 37 and 57
You can tap any one of those Red wires to get the Key ON 12volts
bf750
12
Ky
2. Crap
It is what it is
