- Aug 10, 2014
- 22
- Age
- 31
- Madison, IN
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L
- 2WD / 4WD
- 2WD
- Tire Size
- 215/70R15
I have a Taurus 2 speed fan and accessories for sale/trade. Didn't work out due to my truck having a 2.25" radiator (not the thinner 1" radiator that some other rangers had instead).
The fan was a thrift store find years ago. Bench tested to be good, is an OEM Motorcraft fan. The original electrical connector was cut off by the previous owner (stripped wire leads, crimp/solder your own terminals). I trimmed the shroud as part of my modifications.
I also have the original 1995 4.0 fan shroud modified to accept the Taurus fan. From what I know (and based on my experience), it (with the taurus fan attached) should fit on any 1995-1997 Ranger with a 4.0 or 3.0 and a 1" radiator. It might fit other applications as well; per Rockauto part pictures the radiators used on the 1995+ I4's and all non-electric applications 1998+ look to use the same fan shroud mounting system. All that's needed to rejoin the two is four 1/4" nuts/bolts or rivets. Note: Some spacers may need added between the shrouds to give adequate clearance. No guarantees that additional trimming will not be needed to fit since I wasn't able to fully fit mine with the taurus fan attached. It should be very close though; I used the fan shroud as a mock-up for the thinner fan/shroud combo that did actually fit my application. Had to trim the lower driver's side mounting ear to clear the transmission cooler lines while allowing the fan motor to clear the water pump snout/pulley
Finally, I have (brand new) a BMW 195/210F temp switch & connector, and a 40mm in-hose sensor mount/adapter, originally intended (along with some 30/40A relays that I can toss in) to control the fan. The adapter will need tapped to M14x1.5 (which I can do on request). The switch is made by URO; the connector is genuine BMW. I may return these to Amazon if there isn't any interest though... I'll edit/reply if I go that route.
Price: Make an offer on the fan (and ranger shroud, if interested). I don't have much invested in either of them, and I'm more interested in making sure they go to a good home. The accessories: $40 (spent about $55 on them), but that's negotiable. Not looking to make a buck here, just to put some surplus hardware to better use. I can ship if needed, but would prefer in-person pickup/delivery on the fan/shroud.
Note: the temp switch connector is still on order... but I should have it by Monday (12/14) per Amazon. Kinda funny that that the project fell flat before all the parts came in... oops
