TDI Ranger Build
4EyedTurd
4
Waco, Tx
2.3
Badass build, by far my favorite on TRS
chucky2
Chicagoland, IL USA
4.0L SOHC V-6
I've never looked into 3D printing, although we always hear from the grapevine it can do cool shit.
Are you saying the freaking 3D printer can print up a metal object? Not just some plastic piece but an actual piece of quality metal that can withstand exhaust/turbo temps?!?!
greengeeker
Firefighter
9
Cambridge, MN
1.9L
I simply printed it in plastic. The metal part was machined. There is also sintering metal which is relatively common although not a very cheap method of manufacture.
chucky2
Chicagoland, IL USA
4.0L SOHC V-6
Ahh, OK. I was prepared to be amazed at how far 3D printing had come if it could actually somehow print metal objects like that (like a molten steel 3D printer...hey, maybe they're coming). Very cool idea on 3D printing the test piece, I bet that saved a heck of a lot of time.
greengeeker
Firefighter
9
Cambridge, MN
1.9L
Another trip to Argentina, another opportunity to covet thy distant neighbor's crew cab Ranger...
Among other awesome trucks that we don't get stateside.
Mightyfordranger
157
Ohio
2.9
3in
Clean your room before you criticise the world.
So what the current HP and torque on this thing so far I haven't gotten a chance to check the thread lately
greengeeker
Firefighter
9
Cambridge, MN
1.9L
Here is my post on my last dyno. Basically I have too much fuel for this turbo and if I wasn't worried about cooking this turbo I probably would have ended up with ~145whp. If I had a slightly larger turbo (vnt17) I'd probably be around 160-170whp.
With the new turbo and the larger injection pump (11mm plunger) I should end up in the ~200whp range.
Well I finally got a free day to run this back to the same Mustang dyno as I did before. Went pretty well. Didn't break anything.
I did have to stop the pulls short at 3800rpm due to EGTs. I'm not sure where it would have stopped but it appears to be climbing pretty nicely when I shut it down.
Stage 1 = vnt15, Malone tune (16psi), stock nozzles, 10mm pump
Stage 2 = vnt15, updated Malone tune (16psi), R520 nozzles, 10mm pump
A couple of videos..:icon_thumby:
Fuel pressure: https://youtu.be/r8TmdgXDc7c
Axle wrap: https://youtu.be/QQxBJZRj52o
Boost response: https://youtu.be/iI_pv7e_SiY
Last video is from my first run and it appears I stopped a little early (1610F). My third and best run I stopped at 1650F.
Exenos
Ontario
Your whp#'s match malones advertised chp numbers any thoughts on that or is this dyno known to be optimistic?
greengeeker
Firefighter
9
Cambridge, MN
1.9L
IIRC my buddy said the Mustang we used would trend towards conservative and not optimistic. I REALLY wanted to get a stock truck on the same dyno to serve as a baseline. Until then my dyno numbers are mainly for me to understand the gains made with each performance level.
Exenos
Ontario
Your friend is correct Mustang's should be conservative. You have a jetta right? Why not put that on the rollers? I really don't think that the drivetrain losses would be all that different when comparing 2wd with small tires vs a fwd, a few % at most. It would at least give you an idea as to how the dyno reads.
Exenos
Ontario
Yeah I kinda thought of that after I posted that.
Jfive
Any progress on having some adapter plates made!
