The Dually Ranger
TimShannon
5
Tampa, FL
Subaru
That's a nice-looking Ford Ranger, BlueRanger123. Is that yours?
BlueRanger123
Needville, Texas
Yep, that's mine. ;) I got laid off my job a week ago, but I have an interview for another job tomorrow. If I make enough greenies, I was thinking about swapping the rear tires for ones with a more coarse tread pattern. Same height, and maybe a bit wider.
Josh P
50
Phoenix, AZ
I found a set of Dually hub adapters at a U pull it on a 89 ranger. The rims are junk, 15 inch. Studs are 5/8. Anyone know what the pattern is?
Rick W
4,031
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Should still be 5x4.5 unless someone swapped the axle. Might be a Toyota axle. You should be able to tell.
Are these the long spacers that kind of look like a 10 inch long wheel adapter? Where the outside wheel is bolted through them with long bolts?
Do the look like this?
What are they asking? If you don’t want them, could we work something out for you to get them and send them to me in Atlanta? My interest would only be if they’re standard 5x4.5. Probably need pictures. Happy to send you a few bucks to go back and look. More pictures always better
Mike Tonon
19
Connecticut
Dually Rangers??? 😃😆 For extra weight, right? Like if the owner wants to add a window unit ac to the rear slider to keep his mullet cool? ...”2 wheels, just ain’t enough!”
Mike Tonon
19
Connecticut
Is there a dually BroncoII?
Junk Collector
Truck of Month
4,855
Rapid City SD
