Oh really?
Your question about the coating had already been answered by LeftOfSanity. Did you want me to tell you again?
You want to clean it..... but you don't want to clean it.
Common sense says if it's dirty, then clean it - don't put it off because some sticker says not to. It's not going to magically clean itself. Throttle body cleaner is formulated to clean it and not eat the coating.
Thank you Shane. I appreciate the effort in helping. I was a bit grumpy the other day.
Now to
pbilt.
If you are going to make an attempt at insulting someone, at least use proper grammar. Did it really take three separate posts to create the insult as well? That was a rhetorical question. You can look that word up later. Please do not answer that. Now on to the corrections.
Post #1
Moreflying your an idiot
Let's get a period at the end of that sentence, and (your) is a possessive pronoun. What you really meant was
you're.
Post #2
oh i see now your from California
This entire post is a whopping two sentences. Congratulations! That is a little more descriptive than your first post but not by much. Capitalize your sentence here. When you refer to yourself in a sentence, the "i" Should look like this (I), capitalized. Of course, let's not forget the period at the end of the sentence. Once again I see that you have used the possessive form of "your" instead of the contraction, when two words come together and use an apostrophe. I also observed that you remembered to capitalize California. I knew that deep down you were showing respect for the state.
Post #3
no one answered you question because its a stupid question use sensor safe spray and clean it
Capitalize that sentence as well. You should be (your). I think I hear an echo. Its should be (it's). You really need to work on those contractions. Maybe you fell asleep in class that day. Put a period and the end of the word (question). The word (use) then will be capitalized. Once again put a period at the end of the damn sentence.
Really pbilt, who's the idiot? Take a walk jerk.
