Throttle by wire? 08 Ranger
vfrf2
I've been reading about Toyota's issues with the sticking accelerator pedal (as most have seen by now), some sources mention that the problem is actually in the "fly (err throttle) by wire" system Toyota is using and doesn't have anything to do with floor mats.
I have an 08 Ranger with 2.3 and 5 spd manual and was wondering if Ford implemented similar technology in my truck? Just curious...
locovaca
4
DeWitt, IA
Not in a Ranger. Many newer cars are wire systems though.
TwoWhels
Saginaw, MI
yea and how about the steer by wire cars too
I'm sure all the electrical engineers think it's great idea.
17,972
SW Iowa
I have had throttle cables stick when the weather got cold... runaways are not fun no matter how old/new they are.
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
I really don't think that this electronic stuff is a good idea at all... If for some reason your electronic throttle decided to smash the gas..... or if they started steering by wire "(That would be the worst) your steering module goes out and theres the cliff approching fast, you hit the brake but the fuse blew! And the accelerator sensor went bad, Its going all out!"
News: earlier today a family of 5 committed suicide over the grand canyon. witnesses say they were driving fine but as soon as they hit the last turn... they just gunned it with no attempt to turn at all.
If they put electric wire stuff on cars, no matter how good it is... i'm switching to bikes.
locovaca
4
DeWitt, IA
Steer by wire will be ultimately safer and would save you gas mileage from the reduced weight of the steering column and linkage. It's safer because you don't have a 3 foot torpedo shaped metal of a steering column facing your chest in a head on collision with something bigger than you. It's not out yet but it will be sooner than later.
Think of this: most airplanes now are fly by wire. Rudders, flaps, everything is eletronically controlled. For safety reasons they have sometimes up to 4 levels of redundancy on the modules.
The Toyota problem is nothing electrical. The pedal doesn't return, so either it's getting stuck or a spring isn't working, or something similar. It's not the module going out or anything like that, and if a module does go out you essentially lose your ability to accelerate. You can still move in idle and you're supposed to get to the side of the road.
17,972
SW Iowa
Yeah, F-16's for example are fly-by-wire... and they operate just fine.
Original_Ranger84
20
2.8L, 3.0L
I don't know I still prefer to have physical control over my vehicles, hence partially why I drive a stick.
I just read the Toyota recall thing. I'm really not sure what it is... they are like it gets stuck but not cause of the mat or anything they just do... somthing about the springs and stiff not returning.
masterbrenden
twin peaks,C.A.
ford/ford
3.0l v6/4.0l v6
i drive NEW tahoo's(for our sherrif station) sometimes and i will say, stay with cable, there is so much lag time it them
if you need to get out the way it is not happening
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
to add, in my many experiences with these nightmareish systems. if you disconnect the battery the idle will be shit and you will have poor reaction time and sometimes no reaction at all..
volkswagens in particular you have to have the $10k scan tool to reset the damn things.
fords have low/high idle problems when cold because they get gummed up and have to be cleaned.
i also would not like electronic steering at all.. just THINK about it.. how many monster truck shows have you seen on tv or in person where the truck got towed away because the steer by wire/hydraulic system failed and it wouldn't steer anymore. i've seen plenty
what i DO think is a good idea is electric on demand and variable steering ASSIST, and electric suspension.
engine designers are even trying to come up with electric solenoid operated valves, which would be the perfect solution for power bands. the only problem with that is they havn't figured out how to make it open instantly and then come back down gently so the valve doesn't get hammered/belled.
SMTGREG
MGB
2.3 Lima
MY 2 CENTS.......... the ford drive by wire has 3 sensors in the pedal assembly. If one of the sensors fail the throttle body goes to failsafe mode and will idle only. If more than one fails the engine will go to idle for approx 30 seconds then shut off. Also in the pedal assembly is a tension device that makes the pedal FEEL like a cable is connected to it. (This is probably what is causing the Toyota failures) The throttle body has multiple sensors for redundancy and the throttle plate is spring loaded to the closed position. In the event of a stuck pedal placing the shifter in neutral will cause the engine to rev to the rpm limit speed and not cause damage. People are panicking or playing on their phones causing accidents.
Ford is already using electronic assist steering and electric A/C compressors. Cam timing is also electronic controlled and Now with the ECO BOOST the GAS is injected at high pressure directly in the cylinders. Electronics are here to stay and get even more advanced.
bcost882
5
The Queens Country.....
3.0L, 1.6L
haha f-16's are fly by wire fu** that sh** i won't trust it with my jewels in there. but if the ranger gets "fly by wire" i don't think i will get a new ranger if it is fly by wire especially with other cars with crap like "limp" mode...... like the sentra spec V. who does that crap. sorry gotta clean up the language bein a crew chief and all. hahaha
