Timing a 1993 2.3L!
1993rangerxl
Florida
4 banger 2.3L
This is easily done when the timing marks are available. ,however this is not the case. Outer cover is gone, period. Inner cover was broken off by the same incompetent shop that broke the outer cover. (Shop is now out of business ). I have replaced the timing belt and have it running but has no power, so I know I'm off by one or two teeth in timing. Looking for a different way to get timing done to correct position. Thanks for the help in advance.
8,372
The crank and Aux(oil pump) gear should be easy
Crank woodruff key should be 90deg angle from oil pan, NOT truck, engine is tilted slightly, so pointed up at 90deg from oil pan gasket
Aux gear mark is straight up
Google: 2.3l lima timing belt images
Cam gear should be fairly easy to eyeball with images, look at a few and measure off tensioner or ??
1993rangerxl
Florida
4 banger 2.3L
Would the keyway for the crank be at 12 o'clock for TDC?
8,372
No, but also yes, it is at 12:00 IF engine was sitting straight up and down.
When in the truck the engine sits at a slight angle
Oil pan gasket is the "level line" for the engine, so key way(woodruff key) would be at 12:00 IF "clock" was oriented to oil pan gasket line
1993rangerxl
Florida
4 banger 2.3L
Thanks for the clarification.
Mightyfordranger
157
Ohio
3in
Clean your room before you criticise the world.
Did ya get it fired up??
1993rangerxl
Florida
4 banger 2.3L
Running but still low power, can't even cruise in 5th gear on flat ground. Tinker with it more on Monday.
8,372
Rent or get a compression gauge.
Remove 1 spark plug from each cylinder, you need no compression in other cylinders to get true reading
Put compression gauge in #1 spark plug hole
Crank engine to see what compression is now, you need to "hear" 5 hits of compression stroke to get a good reading, you will know what that means when you crank the engine
1993 2.3l runs 9.2:1 compression ratio
So you should expect 165 psi compression
If at 140 or lower move cam gear over 1 tooth and retest, if lower move cam gear opposite direction
If it is running then you are only 1 or 2 teeth off, or rings are bad and you have low compression from that
If cam timing was indeed off then rotate engine manually back to crank at TDC and cam gear at its 5:00 mark, then add new timing marks on the engine for the next time, also mark for Aux gear
1993rangerxl
Florida
4 banger 2.3L
Motor has 371K miles, no doubt about low compression. Doing trial and error with timing. Work has been in the way last few days.
1993rangerxl
Florida
4 banger 2.3L
Update, think I have timing right. At least back to its slow 0 to 60 time (about 20 seconds! ) very high mileage motor so I can't expect too much. Been driving it to work last couple of days and seems to be doing ok.
8,372
Good work :icon_thumby:
Thanks for the update
