Tow bar install
Skelly94x4
Law Enforcement
San Diego
I have a 94 4X4
Anyone install a towbar on the front bumper?
I have a pathfinder and looking to tow my ranger down to San Diego.
Just looking for advice, thanks.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yes. I will try to take pics tomorrow.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
I also have a 94 4x4. Not a tow bar on the front bumper, but one below it. Ended up going with a Reese 65107 front mount. Its tucked up pretty nice. I did end up totally removing the lower air valence. One could trim it rather than totally removing it i suppose.
ericbphoto
Overlander in development
16,723
Wellford, SC
6"
I don't think thats what he's talking about. That is a receiver hitch. I believe he wants something like this.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
I kind of figured.
Otis413
117
Cass, WVa
4.0 SOHC
There's also a problem with "flat towing" a ranger equipped with the electric t-case selector, if that's what you have, (I don't remember what year the Ranger started using them) there's no easy way to put it in Neutral. Flat towing with the t-case engaged/ engine off can cause bearing problems. You can select N by unbolting the electric selector off the t-case and manually turning the selector shaft, or you can drop the rear driveshaft while you're towing.
17,958
SW Iowa
Mid 80's
scotts90ranger
4,447
Dayton Oregon
2.3 Turbo
But it's not on all of them... hit and miss, I prefer manual obviously like I strongly believe my '00 V8 Explorer Limited should have come from the factory with the manual 4406 transfer case... it's handy! Except right now with a broken passenger side motor mount, can't use low range reverse...
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I have a 94 4X4
This is how I attach my tow bar to my rangers. There is a 1/4" thick plate that I put inside the bumper to spread the force of the bolt head from pulling thru the bumper. Also have chains attached to the frame.
It's how I towed my race ranger before I got a trailer. But if I was towing a lot I would build brackets off the frame to attach the tow bar.
