towing a jeep?
Will
TRS 25th Anniversary
514
Gnaw Bone, Indiana
Toyota
what gears do you have in your 94? probably 3.27s my truck sucked ass when i would haul a cord of firewood my truck bed bull and 4x8 trailer full. but i swapped to 3.73 gears and it made a huge difference. also you are comparing a ohv motor to a sohc motor. the sohc makes a more power.
your comparing apples to oranges
Below 3,000rpm the SOHC and pushrod motors are very similar.
I see no problem pulling a Jeep with a Ranger. Just find as small of a trailer as it will fit on.
lil_Blue_Ford
6,239
Butler, PA, USSA
4.9L
The Ranger will do it, easy. Like others have said, the total weight may be an issue or may not as far as legal capacity. Get a good class 3 hitch and keep your head about you when you're towing (that'll be a good bit of weight back there), but it can be done.
I have a class 3 hitch on my Ranger, the truck has the higher GVWR despite being a 3.0L (which means it has the larger brakes too), and I upgraded the rear leaf springs to a custom leaf pack. (Stock springs do NOT like to be heavily used, lol)
With my Ranger I towed:
1988 Bronco II Eddie Bauer on a tow dolly from Long Island New York to Kittanning in Pennsylvania (about 700 miles or so). Biggest issue was going downhill without the luxury of trailer brakes (but the mountains I was traveling I'd traveled a number of times and knew how to approach the situation).
1989 Bronco II choptop on a tow dolly from Philly in PA to Kittanning. No problems at all.
1989 Bronco II choptop (now lifted, locked and on 33's) with a tow bar from Butler in PA up almost to Erie in PA, then out to go wheeling and back. Struggled a lil trying to climb the dirt road in the middle of the woods, but wasn't all that bad.
YJ Jeep Wrangler on 34" treads with a tow bar from Erie up into New York state and back.
