Toyota and Yamaha R&D on a hydrogen powered V8
rubydist
865
Denver
Ford Ranger FX4
There is plenty of ability to generate hydrogen in a "clean" way, unlike electricity (in spite of what your clean planet friends think).
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,739
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I think the big issue is cost and the amount of energy it takes to make hydrogen. Everything I’ve read on the subject, fuel cells are the most efficient way to use it.
Even with the ICE route, there is little in the way of negatives as far as emissions go. You burn hydrogen and get heat and water as the emissions. Of course, fuel mileage sucks but it’s do able.
Then there is the storage tank problem. You need a huge storage capacity for equivalent distances between refueling if you go ICE. Fuel cells greatly reduce the required fuel needed. But you are back to the cost and availability for refueling locations.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
All that heat and water is gonna raise the sea levels. WE"RE DOOOOOOOOMED :fie:
don4331
1,353
Calgary, AB
5.3
The ICE route has the nasty long term negative of hydrogen embrittlement. Those nasty little hydrogen atoms get between the aluminium atoms of the piston, and make the top brittle. Then, suddenly it catastrophically fails - that was historic issue. Now, better metals might have fixed that, but older engines would be susceptible.
superj
2,670
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
hydrogen embrittlement shouldn't effect the piston tops unless something hits them though, right? brittle is fine as long as nothing hits them and compression doesn't suddenly increase?
but doesn't heating them pistons during combustion also release the hydrogen embrittlement? i think we have to bake our parts for a certain amount of time to fight hydrogen embrittlement during plating processes where i work. (not specifically in the shop i work, we have a plating shop)
don4331
1,353
Calgary, AB
5.3
Compression increases suddenly every power stroke during compression - although the direction reversal between exhaust and intake might be higher force
The combustion is what is forcing not yet burned hydrogen into the pistons - it effectively baking it in.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Toyota can't do anything themselves anymore. Needed the damn Krauts to make their new supra.. apparently enlisting another manufacturer to make a new mr2.. help from yamaha.. pfft.
sgtsandman
Ham Radio Operator
12,739
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
They aren't the only ones. Lotus uses an Toyota engine in the Elise.
