Clumzi
- Feb 27, 2014
- 1
- Port Townsend, WA
- Ford
- Engine Size
- 2.3
Howdy howdy
So got a code checker for Christmas and finally got around to using it. It spit the following codes;
14
18
33
41
51
88
I reset the codes per the instructions in the book and they come right back. This is from the KOEO test and they are all continuous memory codes.
14 is a mystery to me. Book says Electronic Control Assembly has detected an intermittent loss of Profile Ignition Pick-up (PIP) signal during recent operation. Might of been from knocking a wire loose while changing plug 4 on the intake side.
18 is weird. Truck doesn't have a tachometer, so does this mean DIS problem?
33 - no idea what's up the EGR. Maybe previous owner blocked it off already? Haven't opened it up.
41 - O2 sensor?
51 - wtf? Temp gauge works - not sure what this is?
88 - Again, weird. FWIW I tried the dual coil plug mod and it made the truck run worse.
So yea, truck runs rather well so I was surprised it spit so many codes.
Thoughts? Ideas?
14
18
33
41
51
88
41 - O2 sensor?
Thoughts? Ideas?
