U-Bolt Plate Help
RangerJoey
7
BMore
4.0L V6
Teen Wolf for President!
Hi All,
I just received a set of new leaf springs, hangers, and shackles and am doing my driver's side for the first time. I also went ahead and picked up new U-Bolts. Trying to reinstall everything, I'm noticing my non-OEM leaf pack that sits on the axle block will not fit through the U-Bolt retaining plate. That same nut on the OEM leaf pack slips right through. Not sure the original size nut, but the new pack looks to be 18mm.
Should I just drill through the OEM cover plate or was I supposed to replace that when I picked up the new U-Bolts?
(U Bolts are still 1/2" x 3" Round)
JamesH
That's slightly confusing. You shouldn't drill out the spring plates, if the new ubolt don't fit then you gotta the wrong size. but I think you are talking about the centering bolt for the spring pak. That, i would say don't worry about and drill out to fit. Normally replacing the plates isn't done unless they are broken.
Sent from my Moto Z (2) using Tapatalk
RangerJoey
7
BMore
4.0L V6
Thanks for the reply man! And yes, I should've said, it's that centering bolt. To be honest, the new U-Bolts are OEM identical, (spec wise), but just doing a test fitting before installation, they seem really snug. That could also be that the retaining/cover plate is almost 20 years old.
But if there's not function to the centering bolts, to hell with them I say :D
JamesH
Yeah. The top isn't a huge deal, but the u bolt holes are usually reinforced,so you don't want to mess with them,you can always replace the center bolt with a new one or try to transfer the your old one over too.
cstarbard
4
Oakham, MA
2.3
It do like it be
Sorry to hijack for a moment, but I was hoping you could explain how the u bolt holes are reinforced? I had never heard that before and am just curious
I'm glad you mentioned it because I have drilled some u bolt holes out on plates before :shok: Wish I had known
JamesH
The metal is thicker on some, most of the Tacoma's that I do at work have a strip of extra steel run on the underside as a "backup"/ reinforcement. I'm not 100% sure on Ford, but I know the Toyota's and almost every Chevy I've crawled under there is something extra around the u bolt holes so if the rest of the players fails they bolts don't just fall off. I'll see if I can find any pics later to show you guys.
JamesH
cstarbard
4
Oakham, MA
2.3
It do like it be
Thanks for the answer on that. Makes sense.
I don't know if the plates on my Ranger are reinforced like that. They look like pretty much flat stock with no extra support. I'll have to go look at a spare one in the garage
Assuming they are in fact just flat stock with no extra reinforcements unlike those nice Toyota ones, is it still a bad idea to drill the holes out? I suppose that the larger the hole the less material around the hole, i.e. weaker
Thanks again
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
"I don't know if the plates on my Ranger are reinforced like that."
Most of the older ones I have worked on are not. (Late 80's and early 90's) They are a much simpler design. When I swapped in my 8.8" axle, I considered drilling the plates from the 7.5. but that would have been essentially elongating and enlarging the holes which would have been difficult and dangerous with a handheld drill or even a drill press. The drill bit would have wanted to catch and grab. I went to the junk yard and got plates with the holes I needed. Much easier and safer and no issue of " Did I weaken this and make it dangerous to drive on?".
This message composed solely of recycled electrons. Go green!
