Updating the Tech Library Transmission section - Suggestions Needed
littlefordman
monroe,mi
4.0l
sorry, im new and lookin for answers to fix my first truck
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I would start by using the search button up near the top of the page. You will find a whole bunch of threads on manual swaps. Year doesnt make a difference for 90% of the job, they are all mostly the same. Electrical is going to be most of the difference, unbolting and bolting in a new trans is all the same sh!t.
After reading and learning how its done, then start a thread and ask any specific questions you couldnt find the answer to by searching. Just throwing the "how do I do it?" question out there without searching isnt going to get very many answers.
littlefordman
monroe,mi
4.0l
thank you for the infomation
trikerider
'94
Glacier991 at Explorer forum has about the best write-up I've seen of the A4LD.
helped me a good bit
ecablarn
Michigan, Bay County
Ford / Ranger
302 V8, Mild Frame off Restoration still have bodywork
Leveling 2" Lift
31x10.5xR15
BSME, design, drawing
302 swap with 4r70w vs AOD
How about adding a page on a 302 swap with a 4r70w trans and any improvements as well as stand alone controller and any other necessary changes compared to a AOD swap? Kinda of a comparison of the two and pros and cons?
yeeharacing
4.0 L
Not necessarily transmission related but how about a fluid matrix showing the different fluid types and amounts for different transmissions, t-cases, coolant, oil, diff, etc. and any recommended additives.
classof09stark
North Dakota
Any rebuilding process for the FM 145 would be totally awesome
Bill
898
Sacramento, CA
An updated guide indicating what transmissions are used across the years with various engine combinations. This saves people the agony of having to read through arguments over which of four manual transmissions are matched with the 2.3L Duratec (I don't know the answer, but I know there weren't four transmissions used with the Duratec).
And regarding the forum, Transmissions should have manual and automatic sub-categories.
TwoTon
Oregon Coast
I should (hopefully) be doing a 4r55e to M5r1 swap on my 96 ranger 4x4 very shortly... If it works (somehow) I will gladly be a part in helping create a "swap" page for these two trannys... Vexy has succesfully completed this swap and gave me a few helpful notes, but hasn't responded to my pm. I think Vexy should be willing on giving info on this
KDXRider
A write up on the 4r44e/4r55e/5r44e/5r55e valve body problems and solutions would be a good one parts lists and how too's
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,809
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I'm updating the transmission section if anyone has anything to contribute.
IRKillroy
6
Okinawa
2.9l
Semper Fidelis
I'm hoping an NV3550 swap appears in the Tech Library someday.
WHCreek
Tech Library Suggistion
This may have come at an appropriate time. Since I have little to no idea what I'm talking about this post may make little sense but . . . .
Recently, I had an transmission go out on a 2002 Ranger 2.3L 5 speed manual. I looked in the tech section to find a corresponding model but to me the listings shown are inconclusive. It would appear the a type "M" (which seems to be indicated by the label on my driver side door information), would include all transmission's from '98 through 2011 . When I contacted two salvage yards, they indicate that all 5 speeds from 2001 to 2011 are compatible and when I contacted the dealer, they said only 2001 - 2003 are compatible. Now I am overwhelmingly confused.
It would be beneficial if there were a detailed chart that spoke to all of the configurations, years, engine types, and tranny types. Maybe the chart that is currently posted is what I'm looking for, but I can't seem to resolve my issue. Any help is appreciated.
Syritis
Canda
mazda
Solid Axle Swap 4x4
and for anyone doing swaps the exploder door tag codes will help
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code ... Ratio
41 ...... 3.27C
42 ...... 4.10C
43 ...... 3.08C
45 ...... 3.55C
46 ...... 3.73C
D1 ...... 3.27L
D2 ...... 4.10L
D4 ...... 3.73L
D5 ...... 3.55L
Transmission Codes
Code .................. Model
D (1997-2005) ..... A5LDE / 5R44/55E
D (1992-1996)...... M5OD-R1
J ....................... M5OD-R1
J (2002-2003)...... R1HD / M5OD-R4
M (2000-2001)..... Mazda M5D4
M (1997-1999) .... M5OD-R2
M (1992-1996) .... M5OD-R1
R (2002) ............. 5R55W
T (1992-1995) ..... A4LD
T (1996-2001) ...... 4R55E
U ....................... 4R70W
V ....................... 5R55S
X ....................... 6R60
