V8 Conversion Headers
mavereq
Concrete, WA
The headers that bcbroncos sells might work
Bird76Mojo
1,265
IL
Well, I ordered the 88400's so we'll see how they fit in an 87 standard cab 2 wheel drive soon enough... If not, I'll mod them until they do fit. I have an entire stainless system to hand fab at the same time also. Looking at TIG machines now.
GB :)
marioms1
mustang headers?
will the stock mustang headers work?
85_Ranger4x4
17,907
SW Iowa
No.
SN-95 will work on the DS but the passenger side is the same as a Fox where it points directly at the frame.
Loganwildman
10
Logansport, IN
For those installing long tubes, do you install them when you set the motor in, or after installing the transmission?
benhojnowski
Detroit MI Area
351W
Ripind
You have a pic of those speedway headers welded up?
benhojnowski
Detroit MI Area
351W
No unfortunately I didn't take any picks after I made them, before installing. I do have this video of them on the truck. Passenger side was fairly easy. The drivers side I made the rear 2 headers pipes go under the steering shaft. The front 2 go over and they connect with some cheap flanges I bought. So the collector and rear 2 pipes are fully solid and go on first. Then the front 2 bolt together. It was time consuming but not at all that difficult.
https://www.youtube.com/watch?v=W7qOZYS-OI4&t=4s
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
Make your own headers that exit outside the frame. Much better. less clearance issues. Speedway Motors has a weld up kit for SBF for $150. on sale now for $115. Comes with plenty of pipe, Collectors and flanges. I used it on my 351W swap recently.
https://www.speedwaymotors.com/Small-Block-Ford-289-351W-Header-Kit-1-5-8-Tube-3-Inch-Collector,3842.html
Outside the frame is an option for Ibeam / Gearbox trucks, the Ibeam trucks have many header options, they are much easier to fab up or modify something to work.
Outside the frame will not work on a 98+ Control Arm / Rack and Pinion truck.
#1 Lone Ranger
I have a set of Kaufmann headers that I used on my 93 reg cab 2wd with 5.0. I'm thinking about using them on another Ranger 96 but with a 351w. This is my daily driver, so I don't want to take a year to do it like the first one. Does anyone know if they will fit? I also have the Kaufmann poly motor mounts, which are awesome.
deathbypsi
06/2012 STOTM Winner
MTOTM Winner
79
Mich
2.3turbo
Just scored these for my Bronco2!
Bird76Mojo
1,265
IL
I hope you got those dirt cheap.
How big are those runners? They look huge!
deathbypsi
MTOTM Winner
79
Mich
2.3turbo
Got em for $75
The primary runners are 1 5/8 and the log is 2.5". I got some V-bands to weld to the collectors then blast and header paint
