Vacuum hose from canister purge valve
Badkus
I have been looking for a vacuum leak for awhile now. Just noticed the hose from the canister purge valve is collapsed while the truck is running. I have looked on all the major auto parts stores and I can not locate this hose. The truck is a 2000 2.5 ford ranger. A part number or a proper name for this hose would be helpful. I have pictures I can post when I get home to the computer
drsvox
Prattville, AL
V6 2.8L
Should be able to cut your own length of standard vacuum hose to fit, even if you're replacing a molded hose.
Badkus
Do you know of any vacuum hose that is fuel resistant
Spott
21
SE Idaho
Most auto parts stores sell a flexible rubber "fuel line" that's stout enough to serve as vacuum hose. You just need to know a diameter and length.
Badkus
ty for the quick reply
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Badkus, take the old line in, and let them compare it to their inventory.
Spott was correct, and a flexible fuel line should fit nicely. Don't forget to get any hose clamps while you're there!
Tractor Dan
Near Lima, Ohio
What everyone has said is true. That's when i done to mine. That being said when it comes to hose clamps if you have a Lowes or any hardware store near by get them there. I'm cheap i suppose. You can get i think a 4 pack for $2 or so compared to what the parts stores want.
ugltrk
Aiken co SC
Ranger supercab
FWIW...A fix for keeping the purge valve free of canaser charcoal bits..Bill
