Various issues 2003 ranger edge, (mostly electric)
ChargerOnDavins
two 2003, 1 200
3 Ford & 1 Dodg
I just bought a 2003 Ford Ranger Edge Tremor edition 2wd with 130,000 miles.
It has some rust on the front bumper, where can I find a ford ranger edge bumper? any ideas?
Also, the fog lights don't work. Could they both just be out? I haven't checked fuse yet.
The door lock is wierd, it locks just fine but won't UNlock. (driver's side)
The driver's side window also rolls up slower than the passenger side. Any ideas?
Also rear bumper is bent downward a bit... new bumper? Or could new brackets fix?
No HUGE problems, just trying to figure out some insight on these issues.
The window on my charger is slow on pass side, always been that way. My 2003 explorer doesn't have the same issues. Thought I'd run it by you guys.
triumphrider-1
14
Port Huron, MI
Ford F150
3.7L
For the front bumper I would check the junkyards in your area to see if they have a good one. If not there you can check ebay, craigslist, lmctruck.com, or stuffforyouranger.com (sp?).
The fog lamps could be anything in the circuit. Check the fuse, and bulbs to see if their burnt out. If not those then I'd check the switch then the wires for continuity and voltage.
My locks do the same thing, try cleaning the contacts. If that doesn't work it may be the switch.
Pop the door panel and check the track for rust, debris, etc. My passenger side was the same way, just needed to be wire brushed to get rid of some rust build up. I sprayed mine with a dry-film lubricant afterwards.
What a bit? Could be that the bumper is rolled, or the bracket is bent. Compare the bracket to the other side and see if they look different.
Hope this helps.
ChargerOnDavins
two 2003, 1 200
3 Ford & 1 Dodg
thanks for your help
