SCREWd2V
- Dec 4, 2009
- 0
- Ford
- Engine Size
- 4.0
1990 Ext cab STX 4x4 auto
real quick, love this truck, but its got some issues! i want to get this beast back up to par! almost a year ago i got in a wreck, and since then i've been picking up the pieces.
I have refered to the tech library and also searched the forums for the problems i am having.
right now i have this high pitch "hummm" vibration at 2000 RPM - 2300 RPM every gear (auto) and it is only noticeable under load (motor also shutters at idle but rpms dont drop or bounce, its more like its got a slight case of tourettes)
I'm going to explain all details so that nothing gets left out
after the wreck the driveshaft was destroyed (carrier baring) and i needed a new one.( the truck could barly drive down the road so i don't know if the vibration is related to the driveshaft or not) found the one piece swap on here under tech library and replaced, all u joints were good, fit like a glove, but when i would get up in the 2k-2.3k rpm i would get this vibration... and i wouldn't think it would be driveshaft related cause its only related to rpms and not speed.
also the motor takes a while to turn over and sometimes i can smell raw fuel
i have replaced the motor mounts and the harmonic ballancer and transmission mount, has new plugs and wires, and cleaned the MAF sensor and the the IAC valve.
today i tried the turn the driveshaft 180' but no luck. also when i did purchase it i did not have it balanced
FWIW the body bushings are shot in the front and i ordered a body lift kit and new bushings today
Help me TRS!!!!!
Preston
Help me TRS!!!!!
Preston
