- Aug 6, 2007
- 200
- Age
- 47
- Berrien Springs, MI
- RE Interceptor
- My credo
- If you can't go through it or around it, then go over it.
These are junk. Avoid them. I have a 150cc Pulsar push mower that lasted 1 season. Second season I had to replace the carb because now amount of cleaning could fix the bent non replaceable jet. 3rd season the recoil starter broke and is unavailable from the manufacturer.
So this year because it has been a bad year financially I just bought the new mower I could afford (after weeks of getting used mowers sniped right out from under me and the grass in my yard getting waist deep) which was a powersmart from Walmart.com. This is the cheapest junk mower I have ever bought. If I could get parts for my 40 year old craftsman I would just use that. The powersmart has a 209cc horizontal shaft engine that turns a vertical shaft gearbox that goes to a belt drive to turn the blade. After 4 uses…. 6 hours of engine time… the rings are shot….. it’s burning oil… in 6 hours is fouled 2 spark plugs….. and now the blade shaft is bent without hitting anything solid. Just the tension from the drive belt. Among other small minor problems like the rear bag cover spontaneously popping off when emptying the bag causing the springs that keep it closed to go MIA….. when I attempted to contact powersmart it took a week to get a response and there have been no further responses.
When I call I just get put in an endless loop of hold music, line ringing, silence, and back to hold music. This loop takes approximately 20 min. After an hour (because I’m persistent) it hangs up on you. When trying the tech support line it hangs up on you after 10 minutes.
when reviewing the warranty it says that the mower has to be shipped to their facility in its original packaging at your expense….. shipping both ways costs more than the mower…. I am seriously considering loading this up in my Jeep and driving it to their facility in Illinois because that would be the cheapest option.
When you go to leave a review, if it’s negative …. It just goes into a loop of telling you that you are missing required information and not allowing you to post your review. If it’s positive the review goes right through.
for the amount of money that I have spent on this mower ($193) I could’ve bought a predator engine from harbor freight which has really good reviews…..
To sum up…. If you bought something that is Vietnamesium…. And an important part breaks…. You can not get a replacement because they only support a model for the production period. Once that is up, they no longer support it. And Vietnamesium has a build quality that makes me miss the build quality of Chinese built products…. Sorry for ranting but apparently I have no recourse…. And…. Now way to finish mowing my lawn because my Husquavarna riding mower is too big and cumbersome to get around my trees.
