Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Yes and yes. I can't wait until there are rfid's cheap enough for the automakers to have imbedded in the primer. Then I would like to be able to buy that tech for myself for my stuff. I remember seeing a show on that tech.I have a 00 ford ranger. Im wondering if there is any other vin locations other than the dash plate and the door sticker? Id there any stamped on the body itself?
I believe that the only flex fuel engine that was put in Rangers was the 3.0 and that was started in the late 90s. So if your Ranger is non Flex Fuel, you likely have a 4.0 v6 or a 2.5 I4. (the other two engine options) Since you have 6 injectors, I am leaning towards the 4.0. since your truck is a 2002, you will have the SOHC 4.0.i bought a 2002 ford ranger that had a motor swap done on it, and i am running rich on bank 1 and 2, i have replaced all the 02 sensors, maf sensor, and all 6 injectors, according to the vin on the truck it's not a flex fuel, but i need to know where on the block i can find the vin to see if the motor that they dropped in it was a flex fuel, since i have injectors for non flex in it. I should have stated the motor swap was done by previous owners.
any help would be appreciated as this is my only vehicle and i can't afford it crapping out on me.
yep, the Thread Necromancer asked a somewhat related question a few days ago as he was wanting to determine via VIN what engine he has. From what he posted, I think he has a 4.0 SOHC.The original post is from 2012. The OP has only 2 posts total.
