BAT or B+ is easy, that connects directly to the Battery +(positive), thru a Mega Fuse or Fusible link.
STA = Stator, these are the 3 stationary windings in the case of the alternator, the spinning rotor's electro-magnetic fields generate AC voltage in the Stator, this AC voltage is converted to DC voltage via 2 Diodes per winding.
This is B+
I = ignition switch, it gets power when key is turned on, the power passes thru the Battery Light in the dash, this is the ON/OFF switch for the alternator.
An alternator draws power when it isn't generating power so need to be turned OFF.
This power draw is seen when Battery Light comes on, power is passing thru the bulb to the alternator so it lights up, when alternator starts to generate power then no power is passing thru the bulb so it goes off.
(one wire alternators use an internal RPM switch for this, which shuts off alternator when RPMs drop below set threshold, so battery won't drain when engine is off)
F = Field voltage, the fields are electro-magnets in the rotor.
The field voltage is applied to the rotor thru brushes, the amount of voltage sent to the fields determines the amount of voltage that comes out at B+.
So the Voltage Regulator controls the Field voltage, example: 8 volts going to field would produce 14volts out at B+ assuming alternator is spinning at 2,000 RPM(alternator, not engine), the gain in voltage is from engine power.
S= Sensing voltage, this is part of voltage regulator circuit, it connects directly to Battery + as well, via a fuse or fusible link.
This is how the voltage regulator monitors system voltage so it knows how much voltage to send to the Field.
GND is of course the Ground, usually just the mounting bolts for alternator but many add another Ground wire.
With separate voltage regulator then ground between alternator and regulator should be wired
Never ran into an old Ford with F234
GM yes
F = Field, to alternator
2 = R, to alternator
3 = S, sensing voltage, from battery
4 = I, ignition ON/OFF, from key switch
Opps
Forgot IASF
I = ignition, to key switch
A = B+
S = sensing, to battery
F = Field
