black_demon69
- Jun 30, 2013
- 142
- AZ
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0l
- 2WD / 4WD
- 4WD
i know its not a ranger but
back story is a friend traded a truck for this POS and brake system is all screwed up. he just wants brakes to work so he can sell it. someone completely disconnected and cut the brake line leading from abs unit and the rear brakes. all fittings were loose, MC had power steering fluid in it proportioning valve was modified and leaking..
replaced MC and bench bled 2x, replaced proportioning valve, bled front brakes System had NO brake fluid in it so contamination was only in the MC. front brakes bled fine however the rear brakes wont bleed. i have used a vacuum bleeder (a modified glass peanut butter jar and my a/c vac pump), i have tried the old 2 man pump method. tried to gravity bleed, forced fluid from rear caliper to abs unit after disconnecting line from abs unit.. any other ideas?
