Warn warning?
Denisefwd93
74
South East PA
94 Dana 35, older warn locking hubs, I was a happy camper driving to get ice cream cone about 3 miles then all of a sudden: Snap! Clunk, Buzzzz. Same sound the automatic Hubs used to make on my other truck wtf?
Could it be the axle bearing?
Too dark and cold outside right now.
Is this an omen? I have new manual hubs on the truck I'm going to sell!
switch them over?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
likely a bearing and hopefully the lockout survives.
Denisefwd93
74
South East PA
My neighbor came over we did it in the dark (with a light of course) it's the left side (driver)
Axle turns ok, not really noisy, the hub has a split in a plastic ring with little fingers that goes around a bearing, lots of grease no pieces of metal.
We put the wheel on without the locking hub, it spins well, smooth not too loose, no growl or rumble.
The locking hub definitely made a buzzing noise in reverse and click rolling forward when unlocked.
Not even planning on working on the 4WD until fall maybe even winter so don't really need locking hubs at this time.
Denisefwd93
74
South East PA
I really thought it was the clutch it was so loud, I don't know, I justget a little paranoid with all this stuff it's kind of overwhelming I'm retired I shouldn't be going through this but my situation doesn't allow me the money to do anything else with,
The new pre bled clutch Hydraulics are very tight right up to the top no play whatsoever the clutch disengages and engages like it should we did not change the clutch because we're planning on an engine swap in the winter.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Was it engaged?
When you turn the front driveshaft do the axles rotate freely?
Denisefwd93
74
South East PA
Oh yes checked very easy to turn, that over 2 weeks ago, and the hubs only need to fee wheel
I'm hoping it's just the excessive grease inside the Hub I'm really hoping, but my luck is not that good lol
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Ball joints are tight and arms brakets and bushings good?
Dont know how warns self engage and pop.
Odd issue. Spooky
Denisefwd93
74
South East PA
Odd issue. Spooky
I don't think it's self engaged it may have been engaged I don't actually know, the hubs been on and off so many times the past week it may have been engaged. anyhow tomorrow is another day taking a break
Denisefwd93
74
South East PA
Think I'll just leave that hub off until I get new hubs or parts.
Until I sell my other truck, this 94 beast isn't my daily driver. and I only drive it to check it out things that are fixed, then it goes back in the yard.
Denisefwd93
74
South East PA
Well looks like this trucks going to become my daily driver next week I may be selling the 93 long bed!!
Apparently parts are not sold for the Ranger warn premium locking hubs!
So I'm at a loss until I can afford to get new hub/s!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
dont leave the lockout off if your driving it....if you have to, use heavy plastic bag or whatever to seal it and make sure your studs have enough thread and the wheel dont bind on the caliper. you may need a spacer.
you can buy the warn lockouts. not cheap.
Denisefwd93
74
South East PA
Yep I bought a set for my other truck they ain't cheap then I'm finding out there's no parts available so I'm not happy about that even though the ones I have on this truck are quite old
3 hours looking and working at this thing, seems like the spring doesn't hold the gears separate and when it's put it back together right way, (near as we can tell) the gears actually mesh with each other regardless of the knob setting.
But after 3 hours we still can't figure out why/how it happened!
Denisefwd93
74
South East PA
Update, ( kinda sorta)
Reassemble Johnny 5!!
The plastic bearing "cage" it snaps around the bearing but behind the bearing snap ring that is towards the rotor. This is a sealed bearing that is turning whenever the wheels are in unlocked/ freewheel mode.
When the knob is turned to locked mode, the outer spline gear fits inside the hub housing but slide towards the rotor and over the spline!
We still don't know what made it partially locked, chattering, clicking and buzzing while it was on the wheel my only guess would be that it was partially locked and the grease kept the splines partially engaged,
It's absolutely is not necessary to have any grease in there! If there is any at all it should be around the bearing itself which is basically a sealed bearing, near impossible to go bad.
No disassemble Johnny 5!!
I probably should take pictures but it's all back together and I'm not in the mood to take it apart again!
87xjmike
My warns do the same thing. They cick at me and i can hear it nust going straight at lower speeds. Maybe ill take all the grease out. Still work great but damn they're.
Sent from my LG-H700 using Tapatalk
Denisefwd93
74
South East PA
I often solve engineering problems while trying to sleep at night!
it seems to me, the grease can get behind the outer spline gear which has notches in it that slide in the corresponding notches in the housing, because the grease goes down the center where the knob has little ramps that push the outer Gear in they would actually push the grease under the outside of that spline gear creating a hydraulic Dam.
