Water pump and fan clutch - How do you remove a suck clutch fan?
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
I cant find any info about normal or reverse thread on the 2.8. I just keep finding mixed info or 2.9 info.
901wd#2
11
Vermont
Ford ranger
The threads on every one of these will follow the direction the fan turns. In other words, you wouldn’t want to rev up the engine and have the fan spin off.
I damaged a radiator when I shut off an IDI the first time after failing to tighten it properly. Engine just up and stopped like diesels do, but the fan kept spinning until it fell off the hub.
Junk Collector
Truck of Month
4,851
Rapid City SD
Air chisel... if you can get it in there. Usually I can get them off with the holding tool & wrench - mine are KD brand. Heat may help if you can get a propane torch down in there.
901wd#2
11
Vermont
Ford ranger
A decent wrench and a hammer works too.
Roert42
5,018
Kintersville, PA
Ranger XLT
4.0 SOHC
Only time I tried to pull separate one I had a hell of a time getting it loose, I was replacing the pump and the clutch, just needed to save the fan. Ended up giving up and cutting it apart to get at the fan, fan was sandwiched between the pump and clutch.
8,372
On any engine look at the fan blades
Looking down from the top, if the rear of the blade faces passenger side and front faces drivers side, then regular threads, left handed
Like this /
Left handed or regular threads, "Lefty loosey, Righty tighty"
If blade is opposite \ then right handed threads on fan clutch
As said with either you just need to break it loose, it is wedged from multiple starts over the years
A hard tap on the nut in the right direction will break it loose and it will easily spin off after that
RobbieD
2.9l Mafia
3,558
Georgia
Yes, that ^^^
I put a blunt drift punch on a good spot on the clutch and tap it with a hammer. That has always worked fine for me (and thus I've likely screwed myself for the next time . . . ).
Josh B
1,988
Oklahoma
I bought a set of those, it was a "loaner" set from AZ, with THREE wrenches in the two wrench set.
I told the clerk about it and he looked in it and pushed it back to me.
Well, I kept it, but now I can't find it :D
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I bought the wrenches to remove them. Kinda awkward to use but they have done the job many times.
