It's not old it's classic
- Jul 30, 2011
- 0
- Richmond, VA.
- Ford
- Engine Size
- 2.3L
EEC-IV Problem
My “89 Ford Ranger” (2wd-4cyl-2.3 liter-manual transmission) runs fine under most driving situations. It does however have an occasional engine issue that I am unable to troubleshoot myself. Through some experimentation, I have noted some symptoms, triggers, and manifestations that I think may help someone reading this to pin-point the vehicles problem. I will try to describe the problem as accurately as possible.
WHAT TRIGGERS IT-
The problem is triggered when I am driving, and I have to make a heavy acceleration (basically when I floor it). Flooring it seems to be the ONLY way to trigger it. If I accelerate normally, then the problem doesn’t happen.
ONCE THE PROBLEM STARTS-
Once I have pushed the gas petal past this “threshold”, the engine begins to run erratically. Any time I take my foot off the gas, (or even simply back off of the gas) the vehicle shakes for about two seconds. (like a misfire shaking). Then the shaking stops, and the engine seems to run smoothly again. Then I may get 4-5 seconds of normal operation (sometime more sometime less) Then it will do the shaking thing again. But it will only do this if I am actively giving it gas. If I take my foot off the gas completely, it will do the two seconds of shaking and then will slowly drop to a normal idle as I slow to a stop. But if I start to give it gas again…. back to the shaking! It will continue to do this until I pull over, turn off the key, and then re-start the engine. It will not clear up no matter how far I drive, or hold long I drive until I do a key off and back on.
SOME OTHER OBSERVATIONS-
This has been happening for quiet some time, so I have taken note of some other particulars. Such as;
A) Once the problem starts, the engine idles noticeable higher when the clutch is engaged, through all gears, and driving speeds (basically when I push the clutch to shift, the engine idle doesn’t want to drop even though I am no longer giving gas as I shift to the next gear) It acctually rises considerable during a shift.
B) After I pull over turn the engine off (Which ALWAYS solves the problem) and back on again, the engine idles noticeably lower. So low in fact that it will sometime stall at the next stop I come too. The low idle seems to come back up to a normal idle after a few miles.
C) I can trigger this weird issue at any time simply by flooring the gas pedal for a few seconds..
WHAT I HAVE TRIED TO SOLVE IT-
My first thought was “Throttle position sensor” must be bad. But I have replaced it TWICE only to have the problem persist.
I run code checks all the time on the EEC, and it reports everything is fine. (Of course everything is NOT fine).
I think the problem MUST be in one of the EEC-IV sensors or actuators since turning off the engine “resets” the problem.
Any help, advice or suggestions would be greatly appreciated.
WHAT TRIGGERS IT-
