What are these bushings called
Andy833
Los Angeles
V6 4.0
So im trying to change the bushings not the frame ones but the ones on the joints and i want to know what their called so i can order the right parts, see pictures tonknow which ones im talking about, thanks [emoji106]
Sent from my LG-M327 using Tapatalk
Denisefwd93
74
South East PA
Tie rod knuckle/ends/ball joint. Usually for work like that, you buy the whole tie rod, idler arm and or drag link.
What is your end goal here, because as Denise said, doing what I think you are asking about is highly unusual, and the boots themselves are not usually available by themselves.
Also, almost nothing in any of the pictures you posted would be properly termed a "bushing".
Andy833
Los Angeles
V6 4.0
Your right after i saw the picture he shared i basically need all those components changed,
Also, nothing in any of the pictures you posted would be properly termed a "bushing".
*You're
ericbphoto
Overlander in development
16,684
Wellford, SC
6"
yeah. What she (Denise)^^^^ said. Those are not bushings. After those rubber covers split, dirt and water gets into the joint easier and starts to wear away the metal parts. Then they get looser and looser and looser until one of them comes apart while you're navigating a trail on the edge of a cliff or a busy 10-lane highway at 80mph during rush hour and suddenly you're on the evening news. Your new parts will probably come with grease fittings so you can periodically grease them to keep dirt and water out and make the parts last longer.
Plus, picture #4 looks like the end of a steering stabilizer. It's a shock absorber used to dampen steering feedback. You might be able to get new bushings for that. But it might be easier to replace the whole thing if you think it needs it. It's usually an optional, nice-to-have piece of equipment.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Andy833
Los Angeles
V6 4.0
Thanks Denis le all these parts i need to change mine are shot to hell i just needed names, and no i never planned on just changing the boots that very unusual, now i know what im looking for thanks [emoji106]
Andy833
Los Angeles
V6 4.0
Thank you sir, every thing u described is what im trying to avoid previous owner ran the truck till the tranny was shot so ive been fixing what is mestup as i go,
ericbphoto
16,684
Wellford, SC
6"
Also, there is a great article in the "how to tech" section of this website (see tab at top of page) that will tell you how to get things aligned and driveable after replacing those parts. Then you can safely drive it to an alignment shop if you think it needs fine-tuning or you are not comfortable with your own alignment.
Andy833
Los Angeles
V6 4.0
Also how would i know if its dana 28 or 35 before i take everything apart
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Energy Suspension sells just the replacement boots. Ive replaced just the boots before but only when ive got near perfect tie rod ends with a ripped boot. Generally though when the boots are crap the rod ends are crap too.
Denisefwd93
74
South East PA
You are very welcome, I try to help I've spent a lifetime around mechanical trades, so finding information and learning the right terminology is fun for me. But I try not to second-guess The Experts and I've learned a lot from the gentlemen here.
Denisefwd93
74
South East PA
Check your door sticker code, tags on your axles. I looked you have a 96 4. 0 but it's probably a dana 35
