what coils to use???
4.0B2
151
Walls, MS
4.0 v6
Do the math and you can figure out exactly how much it'll compress under the weight of your rig. 240 sounds right but idk about the height exactly.
4.0B2
151
Walls, MS
4.0 v6
Now on SAS, you may be okay with a softer rate.... Idk.
tomahawk350
26
Johnstown, PA
Ford Bronco II
Im looking for a stiffer rate as I feel my RC springs are too soft. Yes I have a SAS so lengths are ok. What I don't know is a weight of the front end of my rig. Not easy to get either...
Sent from my SAMSUNG-SGH-I747 using Tapatalk
4.0B2
151
Walls, MS
4.0 v6
If you know your compressed height, uncompressed height, and spring rate... You can figure out the other number.
tomahawk350
26
Johnstown, PA
Ford Bronco II
Ahhh. I gotcha now.
4.0B2
151
Walls, MS
4.0 v6
Get me the numbers and I'll help you out. When I get on my ipad or laptop tonight or tomorrow night I'll search for the post from Legoms with the explanation of how it works.
It's in my build thread somewhere
4.0B2
151
Walls, MS
4.0 v6
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
close enough:thefinger:
it sure as hell is not that perfect though.
with the softer coils, running the bags insidethem offers the max capacity from the setup.
worth consideration.
tomahawk350
26
Johnstown, PA
Ford Bronco II
Thx 4.0!! Here's what I came up with:
F=(190 lbs/in)(22.5 in - 16.5 in)
F=(190 lbs/in)(6 in)
F=1140 lbs
My B2 has its orig 2.9/5 spd with a D30 SAS from an XJ. Custom winch bumper and winch w steel cable. Does that number jive? If so, what PPI rate should I be running for best offroad stability/ride?
