- Aug 6, 2007
- 1,761
- Macon/Fort Valley, GA
- Ford
- Engine Type
- V8
- 2WD / 4WD
- 4WD
Starting to accept the ugly truth about my V8 swap. That being the engine probably isn't in as good of shape as I thought. Both engines I ahve are 180k mile engines and I picked what I thought was the better condition off the two. I planned from the start to change the oil after a couple hundred miles so clean it out, so I started out with super cheap (Walmart Super Tech) 10w-30 oil and filter. Well after getting nice and warmed up on a long drive the guage started dancing at idle. Super Cheap oil, so not surprised. Well I changed the oil monday with better Halvoline 10w-30 High-Mileage, read something about highmileage possibly being on thicker end of spec, and a better filter. Still getting the gauge dancing at idle after a 30 mile drive. FWIW this was on a high 80s or 90 drgree day. While driving and when cool the gauge is rock solid, not that it means much since the gauge is essentially an on/off switch.
Given mileage and age, I'm going to put in a new oil pressure sensor and see if it persists. If it does I'm going to step up to a heavier grade oil and see what happens. I'm running 20w-50 in my FE to get good pressure due to wear. If I can run 15w or 20w in this and get through a year or two I would like it. I thinking that building the spare engine is going to happen sooner than later.
I need to do that too. Was going to make and keep a little notebook in the glove box of each of the projects with important info, part numbers, and modifications. Started it on the F-100, but it never made it into the glovebox and I'm not sure where it is now.Yeah, I’m starting to organize notes. I have some notebooks that I’m starting to fill with part numbers. I‘m getting to where I’ve changed so much stuff on so many vehicles that it gets hard to keep track of it all in my head.
That reminds me, I need to top off the trans fluid from having the radiator out.
