What did YOU do today?
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Went to a flea market & walked around there for a couple of hours, this weekend is a big yard sale weekend so checked a few of those out. Mowed again & got the bush hog out for the area between the yard & the fields. Put some old (92) center caps on my escape. All 3 vehicles need washed now, feild work on all sides of me & its windy today. Think i may try my dirt scoop tomorrow.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,793
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Changed a couple seal on the transmission of my fathers F150. Was leaking enough they wouldn’t pass the inspection and he couldn’t get anyone to do it because Automatic transmissions are black magic voodoo.
Wasn’t that bad.
Worst part was refilling the pan with oil. Doesn’t have a dip stick, so you fill it from a port in the side next to the car.
You have to check the level from the same port, while it’s running, next to the cat
The 2019+ Rangers are almost as bad. Instead of the cat, you are next to the flex pipe and have to wear a glove in order to not get burnt. A couple companies make and sell a dipstick tube for the 10R80 transmissions in the Ranger. The same tube might work on the F150.
I can't find the link for the other one but it is about twice the price of the one above.
pjtoledo
3,005
Toledo Ohio
Fords
3.0 2.3
new tires for the 2019 Edge. the factory tires still had some tread left, but are 4-1/2 years old and now suspectable to hydroplaning.
then took the '05 Rangers front right tire off a known bent wheel and mounted it on a suspected good wheel.
skipped balancing, put beads in it instead.
Robertmangrum.rm
Wannabe Overlander
1,641
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
Finished the front bumper and slider install on father in laws Pathfinder. Got his lights all wired up.
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Tried out my 3-point mount dirt scoop today by the well. Works great! got rid of all the extra dirt & filled in some low spots. Got the roller out next & went over where I filled in areas. Took the snow chains off of the lawn deere and hung them up. Gassed up the mowers for the next time they are needed. Hit 80 today, been awhile since its been this nice out.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
Washed all the cars and trucks.
spent about 4/5 hours on the new F250 with the power buffer and no7. Looks like a brand new truck, cleaned up about 60-70% of her battle scars.
Just now realized I don’t have any pictures from when I bought it or I would post before and after pictures
Rick W
4,051
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Slept in, fooled around with Lincoln, checked out damage at a client’s property (homeless guy set a dumpster on fire), returned some stuff to Harbor Freight and bought some more, some landscaping and maintenance, a little on the Raith.
Lazy day.
Watching the ‘56 Americanization of Godzilla with Raymond Burr now (Godzilla, King of the monsters).
CamTheHedgehog
ASE Certified Tech
399
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Lazy day.
This is one of the most American descriptions of a slow day I've ever heard. I love it.
scotts90ranger
4,483
Dayton Oregon
2.3 Turbo
Went to an auction today just to do something on a rainy day that wasn't physical or mental... got some stuff, missed some stuff, will post in the new tools thread later once I stop for the night (probably in like an hour, wanna get like 8 more bolts out...). Spent $138 but got two heavy duty pipe stands (think tall one ton jack stands the right height for the front frame horns on a Ranger on 35" tires on almost the lowest setting), a slew of hammers, big wrenches, some sockets, a couple lifetime supply's of dremel bits, big C clamps and other random stuff...
Then ripped into the '90 Ranger, taking measurements it's more obvious why it does some things...
lil_Blue_Ford
6,232
Butler, PA, USSA
4.9L
Saturday I hit a milestone… or rather found the end of a 44# spool of welding wire right in the middle of a project for the ol farm tractor. Yesterday I dug out the 33# spool I have for a replacement.
CamTheHedgehog
ASE Certified Tech
399
Charlotte, NC
Ranger Edge
4.0 SOHC
Well… one of the glue spots holding my bonded retainer popped off today, so now I am at the orthodontist and am $50 poorer.
Also studied for my engine performance final.
lil_Blue_Ford
6,232
Butler, PA, USSA
4.9L
Did some more frame patching on dad’s Ranger and tacked together some more of my other project with my little welder and found that the 10# spool in that is almost gone so I guess I need to order wire for both welders now because I prefer to have a spare roll on hand
Rick W
4,051
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
My landscaping has been out of control since I was injured and sick (2014-2022), and after taking care of other priorities, when I started to recover, it’s a top priority now. At least I think it is, but I can’t see over the grass to see if most of the rest of the yard is also overgrown.
I’m trying to do it myself, because the biggest thing for my recovery, is more physical activity, increase the aerobic rate. I love working on the cars, but they don’t get your heart pumping.
I also know the best time to do it is right now before we get the summer heat. For that kind of work, I’m good for 20 or 30 minutes, then a 20 or 30 minute break, then 20 minutes more, then an hour break, then10 minutes on, you get the idea.
Sooooo, on the breaks, I don’t have to lay down, I just have to slow down and get out of the sun, cool off, and I go into the shed of miracles, and I just clean up a little bit. Also a monumental task.
Sooooo, on the ‘Raith, I’m ready to mount the two side things on the grille, and I want to use the original high-quality stainless screws that I saved. So in between cutting vines and cutting grass, I put away all the junk sitting on top of my workbench, looking for the little cup of screws.
I’m making progress on the landscaping, and I did find the “cup” of screws. The “cup“ was actually a little box. And do you know where it was? It was in the big box marked “Raith.“. Duh.
I have a box or two marked for virtually every project, every vehicle. As I pull things I need again, or as I acquire items, I put them in the big box, or in that area. I have a bad habit of finishing a task, and just dropping the tools and whatever in front of me, a bad habit aquired when I was really sick and I would run out of energy.
Apparently, it has affected my brain as well. Now I’m very good about putting the little pieces and parts in their designated places, I’m just too old and feeble to remember that that is what I do! Anyway, the workbench is clean, and the screws are found
More real estate, more landscaping, and hopefully more turning wrenches tomorrow (the part I like), before the day is over.
I hope I remember where the screws are and that’s the plan when I wake up.
sgtsandman
12,793
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I swapped out most of the winter wardrobe stuff for summer wardrobe stuff. Empty the plastic tub in the basement of the one to make room for the other.
That was pretty much it other that doing a drill day for August, since the weekend of Truck Nationals is also drill weekend.
Oh, and I filled the water bladder in the 3-day Search and Rescue pack. Then took it for a hike to see how far I could get with the additonal 6.5 pounds. I did better than I thought I would (4.14 miles) but not as good as the 6.5 miles I did when the pack was "only" 37 pounds.
lil_Blue_Ford
6,232
Butler, PA, USSA
4.9L
Ordered four 10# rolls of welding wire. Two rolls of flux core and two rolls of copper coated MIG wire, just so I have spare wire on hand when I need it. At some point I want a spare gas bottle for the big welder too. Hate running out of stuff in the middle of a project and not being able to continue.
