What did YOU do today?
97RangerXLT
TRS 25th Anniversary
3,981
Fishers, IN
2"
31"
well I attended the last part of a home inspection for a house I am buying (pending results of said inspection)... The electrical... omg... got some issues.
background info... house was built in 1960. most stuff has been updated here and there throughout the 64 years. New in 2020 or 2021, 200 amp electrical panel. most lights and ceiling fans within the last 25 years or so, some outlets in the bedrooms are the origininal two wire outlets. Bathrooms have been remodeled, kitchen remodeled, both with GFCI outlets. Utility room has been moved from a closet to a bedroom on the other side of the wall of said closet. plumbing is updated and in good repair. Roof is almost done, will need to be replaced in 3 or 4 years. Garage is freaking awesome.
1. No ground for any of the electricalsystem (new 200 amp main panel and they didn't freakin' ground it?!?!)
2. several junctions are not in boxes in the attic.
3. a couple non working outlets, couple of switches that do nothing.. possibly part of the original wiring that was partially updated and now no longer used but still in the walls
4. one wire in the attic is rubbing on a nail and part of the insulation is worn through (can we say "fire")
a few other electrical issues,
a bunch of stupid crap that I can fix but just annoying such as some door trim that needs replaced due to rot at the bottom of it, and two doors do not close well. both are modern doors and worst case I can chuck them and put a new door in for a couple hundred, and one of the two I might just be able to re shim it and install it correctly after fixing the flooring that one of the owners kids so thoughtfully replaced and botched the job...
Vapor barrier in crawlspace needs replaced.
most of the stuff is little stuff but annoying. going to go back to the Sellers and ask that they get the electrical items fixed by a licensed electrician and give me a couple grand toward teh eventual replacement of the roof... but electricians out there looking at you, @ericbphoto lol
Plumbing and septic/ well seem to be ok otherwise I would call @Jim Oaks to help with the plumbing since he has some hella experience in the matter :)
AJ
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
AJ
Well, if there’s illegal splices and damaged wiring noticed, plus the dead switches and outlets indicate to me that there are plenty more issues that can’t be seen until you start opening up walls. It’s gonna be a huge project, probably needs a whole re-wire. My buddy bought a house that has the same issues. Had a pretty good feedback on the neutral and it wasn’t long before we found our first illegal buried splice. Soon as we found that I said there’s gonna be a lot more of that and there has been. I’ve lost count of the illegal wiring hacked in that we’ve found and all we did was open up the basement ceiling (there was strips of 3/8” plasterboard tacked up to hide all sorts of problems). Someone also put a 20 amp breaker on a 14 gauge wire. Gonna take it one room at a time, gut the electrical and fix it right. It’s a huge and expensive project which is why a lot of people hack it in.
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
Old houses are always a mess with the wiring. 70 years of additions and updates. One of the big reasons I avoided residential work when I got out of school.
Don't envy that.
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
Went and looked at a 2011 F250 today to replace my totaled dodge.
6.2L V8 with the Flex fuel single cab long bed stripper. 170K miles
Not nearly as nice of a truck as the dodge, but in budget. $4500.00 and no rust to be seen.
Body is a little bit banged up, but it was a fleet truck. Spent it's life towing around an air compressor.
Only thing I wasn't a fan of was the Auto trans, but for the price seem too good to pass. For what tucks go for around here.
Let me know if anyone has some opinions on the 6.2L. From what I've seen they are pretty reliable engines.
mikkelstuff
469
Brighton, CO
3.0L
Speaking of which - finished adding more outlets to the master bathroom per request of the wife.
What a pain - finding a route to run wire through the wall and into the basement and then wire/conduit back to the outdoor junction box. I do use plastic conduit - yeah wimpy compared to metal but I can do it. (and I hate Romex)
Also wired in a new ground fault protector to feed these outlets - which flat did not work! Luckily I had a spare.
ericbphoto
Overlander in development
16,707
Wellford, SC
3.0L
6"
Sounds like a mess.
1. The electrical system may be grounded at the meter base. Is there a ground wire coming out of the meter and going down to a ground rod? If so, that is usually adequate. There needs to be a green ground bonding screw in the neutral bar in the breaker panel that connects the neutral to ground.
2. Those definitely need to be fixed. But that's usually simple to do.
3. All abandoned stuff, wiring and devices, should be removed, even if just to remove confusion about "is this hot or not?"
4. The wire rubbing on the nail should be an easy fix.
As someone else mentioned, these issues point to the probability that there is more. Be wary, very, very wary.
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
I got a line on 13 medical oxygen tanks for little money, going to look now. I think they are “E” tanks. What do you guys think I could do with these things? I’m not planning on using them for compressed gas.
If they are “E“ tanks, they’re too small to split and put a bottle of Jack Daniels inside.
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
They’re all mine for 100 bucks. 14 E cylinders, one D jumbo/M22, two carts, three regulators, and two boxes full of who knows what.
All visions and suggestions welcome.
And a stainless rack for 12 of them
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
I got a line on 13 medical oxygen tanks for a little money, going to look now. I think they are “E” thanks. What do you guys think I could do with these things? I’m not planning on using them for compressed gas.
Make them into Bells and sell them.
Go on the internet and search pictures of tank bells. Real popular art thing people do.
Robertmangrum.rm
Wannabe Overlander
1,635
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
I'm thinking mini kegs for the trailer project.
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Make a rocket.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
pjtoledo
2,991
Toledo Ohio
Fords
3.0 2.3
what PSI?
extended use for air rifles on range day? :dntknw:
