What is the largest tire I can put on this truck??
Oklahoma
3.0 L
I have a 2000 ford ranger 4x4 with a 3 inch body lift. It has size 32x11.50xr15 tires on it...what is the largest tire I can replace back on it? I know the rim size and other factors come into play, but if rim replacements were in the picture as well, what can I go up to without rubbing or other problems?
Mattyd
Providence, RI
With a grinder...anythings possible. I ran 35x12.50 with my 3in body lift.
truckfan
13
You can fit 35's but still depends on the width and offset. I recommend going with 33's. They would look better.
ghunt81
Clarksburg, WV
You could always crank the torsion bars to get a little more lift.
I just put 32x11.50's under my truck with just a torsion crank, they look great...I'm not sure if I'd want 33x12.50's, I think they would be too wide honestly.
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I run 33x10.5 tires on my Ranger with the original wheels. I just have a 1.5" torsion bar lift and air springs in the rear. I did have to adjust the mud flap brackets to get clearance at full steering turn. I take it off-road quite a bit and have been through some pretty rough stuff without the tires rubbing.
I am at the limit now. Any tires larger would not work without more lift or body trimming.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
40,s
fo sho.
