What kind of shocks do I need to buy?
SamC777
6
Oklahoma
1994 XLT 4x4. Not sure what kind of shocks I need. Those part numbers (740075, 740085) aren't popping up with anything. Rear lift measures 25" from wheel center to the arch and 23" in the front
<front - rear>
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I popped Rough Country in before your part number.
These are for a 2 1/2 - 5 inch lift.
Scroll to the bottom and it give shock specs... might want to measure what you have and compare.
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
Get air shocks I love the way they ride
gaz
659
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
@SamC777 ,
I 100% recommend calling James Duff LLC to learn more about their 70/30 shocks and dual shock kits. Tell them what you have, they will have you take a couple measurements, they are great to work with.
Ultimately, if you desire to have a MUCH safer driving experience, with virtually zero body roll, look into their dual shock set up. Use dual 70/30 shocks both front and rear, it is just plain magicical how they control body roll.
When turning the inside 2 shocks extending with 30% resistance each, equate to approximately a single 50/50 shock while the 2 outside turn shocks with 70% resistance to compression function as a triple 50/50 shock setup!!! While driving strait they all are 70% resistance to compression and 30% resistance to extension. Makes for a very smooth, controlled driving experience.
