What to do about stripped screws...
MastuhWaffles
11/2014 OTOTM Winner
69
Texas
4.0L SOHC
I need more sleep.
On my 835B nitro buggy I have loads of stripped screws really from just wear and tear, and I have no idea what to do to get them out. Any ideas?
Road Angels
27
cold as hell
2.5L
Depends recessed can be sloted or reverse drill bitted out, above surface, Sears and others make extractors that will grab the head and have teeth that dig into bolt heads, some can have a stud welded to them and vise grips used to turn the welded stud or the one I hate the most is center drill the bolt and use an old fashion screw extractor, but most of these are not for rc stuff so a small pair of vise grips on those tiny screws or dremel with a cut off wheel to slot the head but you need a steady hand, I think they make small reverse drill bits or you can take a standard bit and grind the head to the opposite direction and run your drill backwards it should dig in and loosen them
martin
26
St Bruno, Quebec
1991
Take a small round file and grind the end like a reverse drill. mount it in a tap handle and try to remove them with that.
MastuhWaffles
69
Texas
4.0L SOHC
I need more sleep.
I will try something because I need to get them out to get to the A Arms.
swynx
9
lewiston idaho
Mazda
Try and pull on the screw a little while turning it. Ussually I can back stripped screws out this way
