Whats the deal on a c6 and np205 combo
starsnbars
I have a 89 ext cab ranger with a 3 inch body lift and im getting ready to drop a 302 in it i also want to run a c6 and np 205 combo but i dont see many people using this combo i know its longer and bigger then a c4 but is there anything else i need to know i really dont feel like buying the 4wd adapter for the c4 its pretty expensive. I already have a np 205 and i can pick up a c6 for a SB alot cheaper then the c4 adapter
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Body lift is pretty much required. It's tight but it fits. The 205 fits real nice in there. The exhaust gets tight.
projectnitemare
8
Osceola Mills, Pa
396W
As long as you find a 4x4 C4, they are out there you can use a NP205 with that as well. People don't like using the C6 because it's big and eats up power especially in stock form. On a stock 302 it's almost overkill in most opinions. The 205 is a little monster as well. Great t-case but lousy low range. Some use the lighter NP208 or the swap kit and the stock t-case. Most people use a kit with a C4 because it is easy and you can get away from getting driveshafts made. You chose a heavy duty setup, as long as everything is in good working condition you will have a hard time breaking it.
Matt
