Which is the better route to go for a small lift?
Richard869
Law Enforcement
7
St. Marys Pennsylvania
Ford Ranger XLT
I’m looking to add a few inches, would someone just order shackles that will lift your ranger or would you go with the add-a-leaf route?
Roert42
5,036
Kintersville, PA
Ranger XLT
4.0 SOHC
I don’t think the 2011s had the factory lift blocks under the springs. The earlier models had them, they got rid of them for fuel economy reasons.
I think the last year was 2004 or so. That would be the easiest for a small lift.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
My 2wd 2011 came with factory lift blocks. I can snap some pic's tomorrow if needed
Blmpkn
Toilet enthusiast
6,422
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
My '10 didn't have any
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,585
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They lowered the ride height on MY 2008 until the end of production. They removed the rear lift block and also used a different torsion bar key in the front.
Here is some information from the Tech Library.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Now I Think they are lift block. I Could be wrong, I'll take pic of what I think are the lift blocks
17,975
SW Iowa
I did shackles on mine so I could delete the factory lift blocks.
sgtsandman
Aircraft Fuel Tank Diver
12,803
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The 2008 - 2011 4X4 Rangers have a rear axle block that is about 3/4” thick and the torsion bar keys are indexed differently.
If you get rear axle blocks from or for an 1998 - 2007 4X4 Ranger and the same with the torsion bar keys, that will give you about 1.5” of lift.
fastpakr
2,849
Roanoke, VA
You can also swap out the entire spring pack and lift block assembly. That's where my '99 is with Sport Track springs. I'd originally installed a lift block on top of the factory block, but the spring swap allowed me to remove both blocks and maintain the increased height.
superj
2,714
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
you can get those from the edge models for those years too. my 04 edge has huge lift blocks on the back springs.
