RedRangerSTX
- Nov 25, 2007
- 0
- Age
- 40
- Ford
- Engine Size
- 4.0L V6
I have a '02 Ranger FX4 4.0L extended cab. I need to replace the two rear parking brake cables, but I am at a bit of a loss on which ones my truck should use and haven't really found a clear answer while searching.
When you look at online auto parts stores, they offer the following two options for each side (left and right):
I would assume if any of the Rangers had an "HD suspension" that it would be the FX4, as the '02 FX4 is the same as the '03+ FX4 LVII models in terms of suspension and that is the highest level "off road" suspension that was offered from the factory to the best of my knowledge...
Has anyone out there replaced the rear cables in their FX4? If anyone has part numbers of the cables they used I would be eternally grateful!
- 9" Rear Brakes & 10" Brakes; Exc. HD Suspension
- 10" Brakes; HD Suspension
